First post, by DracoNihil
[ 1595.501289] usb 5-2: new full-speed USB device number 4 using ohci-pci
[ 1595.676424] usb 5-2: New USB device found, idVendor=046d, idProduct=c21d
[ 1595.676428] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1595.676431] usb 5-2: Product: Gamepad F310
[ 1595.676432] usb 5-2: Manufacturer: Logitech
[ 1595.676434] usb 5-2: SerialNumber: C988AC53
[ 1595.678535] input: Generic X-Box pad as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/input/input16
[ 1604.052226] usb 5-3: new low-speed USB device number 5 using ohci-pci
[ 1604.240906] usb 5-3: New USB device found, idVendor=046d, idProduct=c215
[ 1604.240911] usb 5-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1604.240913] usb 5-3: Product: Logitech Extreme 3D
[ 1604.240915] usb 5-3: Manufacturer: Logitech
[ 1604.271172] input: Logitech Logitech Extreme 3D as /devices/pci0000:00/0000:00:13.0/usb5/5-3/5-3:1.0/input/input17
[ 1604.271303] logitech 0003:046D:C215.0004: input,hidraw0: USB HID v1.10 Joystick [Logitech Logitech Extreme 3D] on usb-0000:00:13.0-3/input0
Am I missing something here or, are gamepad's so serious they need to be high bandwidth devices? I would of figured a full range joystick with twist and throttle control would need more bandwidth.
Steam Profile
YouTube Channel
Seal of Nehahra
Reply 2 of 8, by SquallStrife
The USB chip doesn't know what the device's true bandwidth requirements are. When the kernel USB driver reports high or low speed, it's just telling you how the USB device has identified itself.
So all this means is that the game pad manufacturer specified "I am a high speed device" in the firmware, not that actually needs 11-480Mbps of bandwidth to operate.
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 4 of 8, by dr_st
Well, the F310 has, in addition to the gamepad, 2 analog sticks, and two analog triggers. Altogether it's probably not less complex than the Extreme 3D.
Reply 7 of 8, by DracoNihil
Has anyone got the Logitech Extreme 3D to work on, say... a Windows 9x machine? Since it's USB 1.0
Steam Profile
YouTube Channel
Seal of Nehahra
Reply 8 of 8, by Matth79
Full speed is not "super fast".
USB1 defined "low speed" 1.5Mb/s and "full speed" 12Mb/s
USB2 added "high speed" 480Mb/s - not sure if there is any difference at all between a device claiming to be USB 2 full speed and one that is USB1
