I know this is going to sound strange but... I've never intentionally or accidentally done anything to severely screw up an electronic device or computer. :o
I've been extraordinarily careful with these things since childhood and as a result, I've never encountered any situations which would really qualify as "dumb things I've done on a computer". I've done things which have caused problems for sure, but that's the result of doing something which SHOULD have solved an issue, only to result in a new issue being created in the process which made no sense. (Like trying to install a video driver update on Dad's system and breaking access to almost everything in the Control Panel in the process despite not doing anything wrong.)
Mind you, if we go back to when I was like, three or four years old, I used to stick pennies into the slots on the back of our TV set. Resulted in techs coming out a couple times to deal with that. :P
However, when I was a kid, I had to bear witness to some extremely stupid scenarios due to people around me (or more so my mother) who were supposedly "more experienced" than me with computers, thus my own opinion and recommendations would be ignored. One time was when we had one of Mom's friends out to try and fix the CD-ROM on our system as it was giving random bit errors. While watching him work on it, one of the "fixes" he tried was changing the "keyboard refresh rate" in the BIOS. That's seriously the only setting he changed before trying to reboot the system and test the CD-ROM. His initial conclusion was that the games I was trying to play were "too powerful for the CD-ROM drive to handle". Later on we had a floppy drive problem which appeared out of nowhere and when he tried to fix that one, he concluded that the motherboard was physically chipped and needed to be replaced... and when we got the computer back from him the CD-ROM was working properly for the first time ever... somehow. More on that later.
This is what led to our upgrade to a P120, back when 166 MHz was considered top of the line, but due to another of Mom's friends, it almost didn't work out that way, as this other friend suggested going with a cheaper 33 MHz board with more RAM under the suggestion that, "You'd be surprised how fast the system will go with more RAM." Luckily for me, that motherboard didn't physically fit into the case... something you'd think someone with some level of computer hardware knowledge would've been able to figure out without actually trying to do it first. He let us keep the RAM though, so we ended up with 16 MB of RAM on top of the 8 MB already in the system, thus 24 MB RAM at a time when 8 MB was more than enough for most people. :)
Eventually, the first of these two friends went silent after screwing one of Mom's other friends over and Mom slowly realized I knew what I was talking about much better than her friends ever did despite being a teenager and less experienced. This ultimately led to me being the one to replace the CD-ROM drive in said P120 when it failed for good. This was the first time I opened up the P120 on my own accord and when I was attempting to take the CD-ROM out I noticed how tight the power cord stuck into the thing and the sheer amount of force it took to remove it. When I went to put the new drive in my hand merely brushed against the power cord for the hard drive... AND IT FELL OUT. o_O;
If the person who had worked on Mom's system all those years couldn't even plug in a power cord properly, that might've gone a long way to explain the random bit errors the CD-ROM had when it was first installed which ultimately disappeared without explanation, as perhaps the power or data lines simply weren't plugged in perfectly and he had inadvertently knocked one out and put it back in or something? *shrugs* :P
But yeah... even building a system from nothing but components for my very first time, leading to my current 4 GHz system, ultimately succeeded without issue. The very first boot saw no smoke or sparks or blown components or anything.
I have yet to do anything stupid when it comes to electronics or computers and after over 20 years of practice I'm not about to start anytime soon. ;)
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
