First post, by Nic-93
Heya, i had treid to get a computer with windows 98 SE to work with the Voodoo 3DFX card but it sems to cant find even with drivers, but unfortanly for now the power supply not working, but anyone got a clue to why not it wont find it?-
Reply 1 of 14, by kixs
Clean the PCI contacts on the card. Put it in another slot.
As the Pentiums and Voodoo are both PnP, BIOS should list it at boot time as Multimedia device or something.
Reply 2 of 14, by Nic-93
This computer i have cant really be told is a pentium but it perhaps might be and is strong enough to run it Win98SE
and the graphics is passed thou fine wich is weird.
Reply 5 of 14, by alexanrs
700? As in 700MHz? If it is a Pentium, it is a Coppermine Pentium 3 most likely. The original Voodoo had issues running on PCs that are too fast (the Voodoo2 is much better in this regard, with only a few driver versions having this issue), and I think 700MHz CPU is way past what a Voodoo can handle.
Reply 8 of 14, by idspispopd
Nic-93 wrote:
And the computer is from the year 2000 was pentium 3 new there?
Sure, P-III 700 (Coppermine) was released in October 1999.
Reply 9 of 14, by oerk
You haven't told us which Voodoo card. Could be a Voodoo 2 for all we know.
A trick that works for me almost every time: Install the oldest Diamond drivers you can find (doesn't matter if it's not a Diamond card). This should work. Then you can install the driver package you want (latest reference driver, 3rd party...).
Reply 12 of 14, by Nic-93
Would i need to change that in the bios? it has no butten on the front, the amazeing with this computer thou when i bought it second hand the machine was virtually in stock condition and not that very much touched on so it was very easy to clean up the computer.
