Reply 80 of 170, by PhilsComputerLab
- l33t++
@ mr_bigmouth_502
Science Studio claims to have used an older AM2 board and the machine shutting itself off. He didn't show a video of this though, that would have made it even more dramatic.
Newer boards are simply more tolerant I guess. Reminds of the AGP power draw issues with V3 cards. Although here it was the motherboards that cut corners.
A driver update is coming, but can you put a current limit on the PCIe slot through a driver? AFAIK what cards do, when you OC them even, is hard limit the PCIe power draw and get anything extra from the 6 pin or 8 pin plug.
Any way, we will know more soon. AMD can be sure that reviewers will re-test this with eagle eyes, so they better fix it properly.
Still, it's huge stuff up. For a chip that was hyped for its energy efficiency to come out and break specifications? Not a good thing 🙁
And of course they knew about the issue! A reviewer even said that during a press talk, AMD straight up said that 150W is not the maximum, but the typical load you will see while playing games.
Still, a great bang for you buck card, if they can sort out the driver. The RX470 might be the safer card to go for...
