First post, by Robin4
- l33t
Iam looking for some help here.
I never owned windows 2000 by my self back in the days ,so i dont have the right information in my brain on which official genuine windows 2000 updates where released by microsoft by then.
Iam running windows 2000 sp4 now on my windows 2K gaming build and had some patches installed to get my ATI catalyst version 5.12 graphics driver working.
I had to install this to get the ATI catalyst config menu execute otherwise it wont run.
How To Install .NET Framework 3.0 and 3.5 on Windows 2000
Normally, the .NET Framework versions 3.0 and 3.5 will not install on Windows 2000, however, we have found a way to accomplish this. Carefully follow these instructions.
You must have Windows 2000 SP4 in order for this procedure to work.
1. First, you must have the .NET 2.0 SP2 Framework installed, but before this will install on Windows 2000 SP4, you install this Microsoft patch first (very important):
Security Update KB835732 for Windows 2000
2. Now, you must install the .NET 2.0 SP 2 update because the .NET installer (in the next step) will not run without it:
.NET Frameworks 2.0 SP 2 Update
3. Now you can install this custom utility that installs both the .NET 3.0 and 3.5 Frameworks on your Windows 2000 SP 4 computer:
.NET 3.0/3.5 Installer for Windows 2000
I already did this and the graphics driver works perfectly then..
Iam really curious what security fixes, and patch fixes iam still need to install here.. I know windows 2000 isnt supported anymore by microsoft and there are not comming any new fixing out.. But i still want to patch the system as far as possible to the max.. First i want to go on with the genuine ones, and later i also want to install the unofficial one..
Are the role up updates on only one fixes / security updates after Service pack 4?? Someone that can guide me to the point i want to be..and getting this things done. Iam only want to run windows 2000 software on this system, iam not intrested for running windows xp software on windows 2000 sp4.
