First post, by Jorpho
- l33t++
I recently upgraded a Toshiba Satellite laptop from Windows 7 to Windows 10. Before I ran the upgrade, I downloaded the free verison of Macrium Reflect, installed it to a USB drive, and made an image of the hard drive. Everything seemed to be fine – I was even able to restore the image without any problems after I managed to botch the upgrade the first time. (Specifically, I tried to revert the hard drive to the factory default, but that turned out to be Vista Ultimate. But that's not important.)
Now that I have Windows 10 installed, I want to make another backup of the hard drive – but I can't. Macrium gets most of the way through before giving an "Error 1117". I also tried Paragon Backup running off a bootable CD (it's Linux-based instead of WinPE based), but that stops near the end with an "Error 0x80".
Googling around suggests that if Macrium gives Error 1117, then no other backup software will work, because it's actually something happening at the system level. Supposedly the solution is to run chkdsk /r /f, which I have done repeatedly, to no effect. The drive seems to be fine, and so do all the drives I've been trying to store the images on.
It occurs to me I can try booting a proper Linux distribution and try good old-fashioned Partimage. Any other ideas about particular software I should try? Toshiba doesn't really seem to have much available.
