First post, by Kerr Avon
Today I had to build a PC based on a (modern) Gigabyte motherboard, and was amazed to find that the motherboard doesn't support the POST-based beep error warning system, And apparently other motherboards have already dropped this feature, even though it's been a very helpful part of PC motherboards since at least the mid 90s (when I started to build/upgrade PCs).
So why has something so helpful (many might say necessary) been removed? It's not like the Gigabyte motherboard I put in had an alternate system, such as flashing LED to show errors (or an LCD display, etc). And even if it had, I'd still expect them to leave the beep system in as well, as it's such a well known system. I can't imagine why they've dropped it, I mean, even if they thought it was no longer necessary (and it definitely still is) then how much would they save by removing the motherboard to case-beeper connection and the related circuitry and firmware? Pennies, I'd expect.
Does anyone know why this feature was removed, and are more motherboards likely to emerge without this feature? And how do the manufacturers justify removing this?
