First post, by superfury
What was the on-board speaker on the Sound Blaster 1.X/2.0 used for? Could it only produce the test tone(2KHz sinus)? Was it enabled using the Speaker Enable/Disable DSP commands? Or is both the speaker and line out enabled/disabled using those commands? Or is the output switching between line out and the little speaker, depending on whether or not something is connected to the line out port?
UniPCemu Git repository
