First post, by computergeek92
I heard 8 pin cpu power is necessary for really hot running cpus, but would having it for an energy efficient cpu make any difference versus just using the 4 pin cpu power? Is there anything more than just extra overclocking stability?
What is the point of using EPS power connections on a server motherboard? I’ve seen the old dual Coppermine Pentium III systems with unused EPS connectors. They worked just fine with out the extra power.
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
