Jade Falcon wrote:ZellSF wrote:It'll take at least 25 years for daily 10GB writes to wear down a good SSD. People are way too paranoid about reducing SSD writes. By the time you will wear down a SSD by Firefox use, it will be severely outdated. The time you spend trying to reduce SSD writes is really better spent elsewhere. Your SSD is more likely to fail from another cause than maxed out write cycles anyway.
I seen a few sdd's ware down in less then 3 years. it can happen fairly fast on cheap ones.
A lot of SSDs fail in short time, but not due to exceeding write limits. If you have a SSD that ran out of write cycles after 3 years, it was faulty from the day you bought it. Even if it wasn't, doesn't spending a few dollars more for a drive that'll last 10 years more make more sense? Do you really want to tweak your system so you can store data on a drive you don't trust?
clueless1 wrote:ZellSF wrote:It'll take at least 25 years for daily 10GB writes to wear down a good SSD. People are way too paranoid about reducing SSD writes. By the time you will wear down a SSD by Firefox use, it will be severely outdated. The time you spend trying to reduce SSD writes is really better spent elsewhere. Your SSD is more likely to fail from another cause than maxed out write cycles anyway.
It took all of 1 minute to adjust that value in about:config, so I don't see it as time better spent elsewhere. I like my hdds to last forever if possible. In 20 years you may want to use that SSD in a Win7 retro PC. 😉
In 20 years you can buy the highest end SSD available today for next to nothing.
clueless1 wrote:
I bet Mozilla responds to this in some way, so that future versions will be more write-thrifty without users having to tweak any settings. But for now, the option to tweak is there for those who are interested 😀
Not sure which part is more hilarious here, the one about Mozilla listening to users or the ones where Mozilla is supposed to care about something which all research points to not being a problem.
And Firefox has been HDD intensive for ages. It's why I used to use Opera (when it wasn't a Chrome skin), it's why my USB Linux stick copies my Firefox profile to a ramdisk whenever I boot it. It isn't likely to change now, especially not at the cost of a feature that makes sure user data isn't lost.
