First post, by keenmaster486
- l33t
So for my Computer Science class, they assigned a project entitled "Design your own game".
Here's the writeup on it:
In this project, you will be designing your own interactive computer game. Yep,
designing your own game. The idea for the game and the code to implement your
idea will come from you. The only requirement for the assignment is that your game
include the following programming features:
At least:
• 4 functions
• 2 loops (either while or for, or one of each)
• 4 if/elif/else blocks
• 4 numerical variables
• 4 strings
• File I/O
o Reading from or writing to a file.
• Console I/O
o Ask the user for input and handle that input.
• 3 classes, including
o At least one base and one derived class
[etc...]
What is a game?
The definition of computer game for this assignment is anything that interacts with
the user and continues going until the user says Quit. Clearly, this is a more relaxed
definition than might generally be used. All user interaction we have done so far has
been command-line based, such as the “I’m thinking of a number between 1 and
100” game that we did early in the semester. You are also welcome to incorporate
sophisticated sound and graphics.
Game subject areas
The subject area of your game is also your choice. If you want to write an
educational game that quizzes your knowledge of chemistry, sounds great. A choose
your own adventure game? This is also a fabulous idea. Help the horse navigate a
complex maze? Great.
So I immediately thought I'd like to try writing a 2D platformer, and then proceeded to put it off until yesterday 😵 😵 😵
So I literally whipped up this code in a sum total of about five or six hours between last night and this morning. I had never used SDL in my entire life before last night; neither had I ever done graphics programming in C before. So this code is not guaranteed to be good 🤣
I'm just looking for everyone's opinions on my programming practices on the whole. Since I had extremely limited time I did cut a lot of corners where I knew they shouldn't be, and I didn't comment very well. But I guess this is interesting because it's kind of a measure of what my base instincts as a programmer are; i.e. what I do when I'm up against the wire and don't have time to make anything but the quick and dirty solution.
Here's the project:
And here's the code if you don't want to mess with CodeBlocks:
#include <SDL2/SDL.h>
#include <stdio.h>
#include <iostream>
#include <fstream>
#include <string>
#include <cmath>
using namespace std;
//############# Project 1 for Computer Science 1310
//TA Name: #################
This project is a demo of a 2D platform game engine.
It requires version 2.0 of the Simple Directmedia Layer Library,
otherwise known as SDL2. You can get this with the command
sudo apt-get install libsdl2-dev
if it's not already installed.
This program also requires the files
TILES.EGA
SPRITES.EGA
LEVEL01.MAP
to be in the current directory when it is run. Otherwise it won't work
since it needs these files for graphics and level data.
How to use the demo:
When you run the demo and skip the user input section at the beginning;
it loads the graphics and level and you're presented with the demo level.
You control a demo character with the following keys:
Arrow keys ----- move
Left ctrl ------ jump
Esc ------------ quit
He's not animated because I didn't have time, but the extra sprites are loaded
into memory anyway.
You can see that there are two total tiles right now; more could be added if needed.
The level does not scroll but the framework to do that is built in.
The keys are a little delayed; I'm not sure why. Something to debug later.
Press ESC to quit the demo.
Note on screen/window resolution:
The program, by default, emulates a resolution of 320x200 on a window size of 1280x800.
You can change this by the constants below. It's kind of fun to fiddle with it to see what you can do.
//===========DECLARE GLOBAL VARIABLES==============
//Screen dimension constants
const float SCREEN_WIDTH = 1280;
const float SCREEN_HEIGHT = 800;
const float SCREEN_SIMWIDTH = 320;
const float SCREEN_SIMHEIGHT = 200;
const float SCREEN_WMULT = SCREEN_WIDTH/SCREEN_SIMWIDTH;
const float SCREEN_HMULT = SCREEN_HEIGHT/SCREEN_SIMHEIGHT;
const float gravity = 1; //acceleration due to gravity (in pixels per loop cycle per loop cycle)
const float terminalv = 8; //terminal velocity due to air resistance
//Loop delay to make sure it doesn't go too fast:
int loopdelay = 20;
//Main rendering window:
SDL_Window* window = NULL;
//Surface on the main rendering window:
SDL_Surface* screenSurface = NULL;
//Renderer:
SDL_Renderer* gRenderer = NULL;
//Event handler:
SDL_Event events;
//Main loop exit flag:d
bool exitmainloop = false;
//LEVEL DATA (just foreground tiles for now; leave room for 100x100 levels:
int lx = 0;
int ly = 0;
int foretile[200][200];
int midtile[200][200];
int backtile[200][200];
//FILES:
ifstream myfile;
float dir(float temp)
if (temp>0) {return 1;}
if (temp==0) {return 0;}
if (temp<0) {return -1;}
bool initSDL()
//SDL initialization code:
if( SDL_Init( SDL_INIT_VIDEO ) < 0 )
printf( "SDL could not initialize! SDL_Error: %s\n", SDL_GetError() );
return false;
else
//Create window
window = SDL_CreateWindow( "2D Platformer", SDL_WINDOWPOS_UNDEFINED, SDL_WINDOWPOS_UNDEFINED, SCREEN_WIDTH, SCREEN_HEIGHT, SDL_WINDOW_SHOWN );
if( window == NULL )
printf( "Window could not be created! SDL_Error: %s\n", SDL_GetError() );
return false;
else
//screenSurface = SDL_GetWindowSurface( window );
gRenderer = SDL_CreateRenderer (window, -1, NULL);
//Get window surface
//Fill the surface white
//SDL_FillRect( screenSurface, NULL, SDL_MapRGB( screenSurface->format, 0xFF, 0xFF, 0xFF ) );
//Update the surface
//SDL_UpdateWindowSurface( window );
//Wait two seconds
//SDL_Delay( 2000 );
cout<<"SDL initialized successfully"<<endl;
return true;
bool shutdownSDL()
SDL_DestroyRenderer (gRenderer);
//Destroy window
SDL_DestroyWindow( window );
//Quit SDL subsystems
SDL_Quit();
cout<<"SDL shutdown successfully"<<endl;
return true;
void KGEpset(int x, int y, int c)
//Convert c from a 16-color standard EGA palette to RGB
//Why not use the VGA palette like everyone else, you say?
//We do this because we like the EGA palette. It's cool.
int red = 0x00;
int green = 0x00;
int blue = 0x00;
switch (c)
//For reference:
//0x00 = 0
//0x55 = 85
//0xAA = 170
//0xFF = 255
case 0: //black
red = 0x00;
green = 0x00;
blue = 0x00;
break;
case 1: //blue
red = 0x00;
green = 0x00;
blue = 0xAA;
break;
case 2: //green
red = 0x00;
green = 0xAA;
blue = 0x00;
break;
case 3: //cyan
red = 0x00;
green = 0xAA;
blue = 0xAA;
case 4: //red
red = 0xAA;
green = 0x00;
blue = 0x00;
break;
case 5: //magenta
red = 0xAA;
green = 0x00;
blue = 0xAA;
break;
case 6: //brown
red = 0xAA;
green = 0x55;
blue = 0x00;
break;
case 7: //gray
red = 0xAA;
green = 0xAA;
blue = 0xAA;
break;
case 8: //dark gray
red = 0x55;
green = 0x55;
blue = 0x55;
break;
case 9: //light blue
red = 0x55;
green = 0x55;
blue = 0xFF;
break;
case 10: //light green
red = 0x55;
green = 0xFF;
blue = 0x55;
break;
case 11: //light cyan
red = 0x55;
green = 0xFF;
blue = 0xFF;
break;
case 12: //light red
red = 0xFF;
green = 0x55;
blue = 0x55;
break;
case 13: //light magenta
red = 0x0FF;
green = 0x55;
blue = 0xFF;
break;
case 14: //yellow
red = 0xFF;
green = 0xFF;
blue = 0x55;
break;
case 15: //bright white
red = 0xFF;
green = 0xFF;
blue = 0xFF;
break;
//SDL_FillRect(screenSurface, NULL, SDL_MapRGB( screenSurface->format, red, green, blue) );
//SDL_FillRect(screenSurface, NULL, SDL_MapRGB( screenSurface->format, 0xFF, 0xFF, 0xFF) );
//SDL_Rect fillRect = {x*SCREEN_WMULT, y*SCREEN_HMULT, (x+1)*SCREEN_WMULT, (y+1)*SCREEN_HMULT };
SDL_Rect fillRect = {x*SCREEN_WMULT, y*SCREEN_HMULT, SCREEN_WMULT, SCREEN_HMULT };
SDL_SetRenderDrawColor( gRenderer, red, green, blue, SDL_ALPHA_OPAQUE );
SDL_RenderFillRect( gRenderer, &fillRect );
class Graphic
public:
int picdata[200][200];
int xsize = 0;
int ysize = 0;
protected:
private:
class Tile: public Graphic
public:
int type = 0;
int inf[5];
int picdata[16][16];
void drawTile(int x, int y, int page)
for (int j=x;j<=x+16;j++)
for (int k=y;k<=y+16;k++)
KGEpset(j,k,picdata[j-x][k-y]);
protected:
private:
class Sprite: public Graphic
public:
void drawSprite(int x, int y, int page)
for (int j=x;j<=x+xsize;j++)
for (int k=y;k<=y+ysize;k++)
if (picdata[j-x][k-y] > -1) {KGEpset(j,k,picdata[j-x][k-y]);}
protected:
private:
//DECLARE GRAPHICS VARIABLES:
Tile tiles[100]; //Allow room for 100 tiles
Sprite sprites[200]; //Allow room for 200 sprites
class Object
public:
int spr = 0;
int xpos = 0;
int ypos = 0;
int xsize = 0;
int ysize = 0;
float xv = 0;
float xa = 0;
float yv = 0;
float ya = 0;
float grav = gravity;
float fric = 0;
void SetSprite(int s)
spr = s;
xsize = sprites[spr].xsize;
ysize = sprites[spr].ysize;
void SetPos(int t, int t2)
xpos = t;
ypos = t2;
void SetXV(int t)
xv = t;
fric = 0;
void SetXA(int t)
xa = t;
void SetYV(int t)
yv = t;
void SetYA(int t)
ya = t;
void SetGravity(int g)
grav = g;
void ResetGravity()
grav = gravity;
void SetFriction (int f)
fric = f;
void ResetFriction ()
fric = 0;
void Increment()
xa = abs(fric) * -dir(xv);
if (abs(xv) < 1) {xa = 0;xv=0;}
xv = xv + xa;
ya = ya + grav;
yv = yv + ya;
if (yv>terminalv) {yv = terminalv;}
xpos = xpos + xv;
ypos = ypos + yv;
if (xpos<0) {xpos=0;}
if (ypos<0) {ypos=0;}
if (xpos>(SCREEN_SIMWIDTH)-24) {xpos=SCREEN_SIMWIDTH-24;}
if (ypos>SCREEN_SIMHEIGHT-32) {ypos=SCREEN_SIMHEIGHT-32;}
void Draw()
sprites[spr].drawSprite(xpos, ypos, 1);
friend void DoNothing();
protected:
private:
void DoNothing ()
//This is a friend function to class Object since one was required. It doesn't do anything because I don't need it to do anything.
//DECLARE OBJECTS:
Object player;
bool coltop(Object o, int tx, int ty)
//Check if an object is colliding with a particular tile on the top
if ( (o.xpos + o.xsize > tx) && (o.xpos < tx+16) && (o.ypos + o.ysize > ty) && (o.ypos < ty+16) )
return true;
else
return false;
void handlekeys()
if(SDL_PollEvent(&events) != 0)
if (events.type == SDL_QUIT)
exitmainloop = true;
else if (events.type == SDL_KEYDOWN)
switch (events.key.keysym.sym)
case SDLK_ESCAPE:
break;
case SDLK_UP:
//do something for up key
break;
case SDLK_DOWN:
//do something for down key
break;
case SDLK_LEFT:
//do something for left key
player.SetXV(-6);
player.SetXA(0);
player.fric = 0;
break;
case SDLK_RIGHT:
//do something for right key
player.SetXV(6);
player.SetXA(0);
player.fric = 0;
break;
case SDLK_LCTRL:
//do something for left control key
//JUMP!
player.SetYV(-20);
break;
case SDLK_SPACE:
//do something for space key
break;
case SDLK_LALT:
//do something for left alt key
break;
void displayLevel (int scrx, int scry)
int cx = 0;
int cy = 0;
for (int j=0;j<=SCREEN_SIMWIDTH/16;j++)
for (int k=0;k<=SCREEN_SIMHEIGHT/16;k++)
cx = (j*16)-scrx;
cy = (k*16)-scry;
//KGEpset(cx,cy,15);
//if (backtile[j][k] > -1)
// tiles[backtile[j][k]].drawTile(cx,cy,0);
//if (midtile[j][k] > -1)
// tiles[midtile[j][k]].drawTile(cx,cy,0);
//if (foretile[j][k] > 0)
tiles[foretile[j][k]].drawTile(cx,cy,0);
if ( (coltop(player, cx, cy)) && foretile[j][k] > 0 && player.yv >= 0)
player.ypos = cy-32;
player.ya = 0;
player.yv = 0;
player.fric = 2;
void mainloop()
player.SetSprite(1);
SDL_RenderClear (gRenderer);
SDL_RenderPresent (gRenderer);
while(!exitmainloop)
SDL_Delay(loopdelay);
//sprites[1].drawSprite(0,0,0);
//tiles[1].drawTile(50,50,0);
displayLevel(0,0);
handlekeys();
player.Draw();
player.Increment();
player.ResetGravity();
player.ResetFriction();
void LoadGraphics()
//Loads graphics from files TILES.EGA and SPRITES.EGA:
cout<<"Loading tiles..."<<endl;
string temp = "";
int temp2 = 0;
cout<<"Opening file...";
myfile.open("TILES.EGA");
cout<<"Done."<<endl;
cout<<"Reading number of tiles...";
getline(myfile,temp,'\n');
int tilenum = stoi(temp);
cout<<"Done. There are "<<tilenum<<" tiles."<<endl;
cout<<"Reading tiles";
for (int i=1;i<=tilenum;i++)
for (int k=0;k<=15;k++)
for (int j=0;j<=15;j++)
getline(myfile,temp,',');
tiles[i].picdata[j][k] = stoi(temp);
//cout<<temp<<",";
//cout<<endl;
cout<<".";
getline(myfile,temp,';');
myfile.close();
cout<<"Loading sprites..."<<endl;
temp = "";
temp2 = 0;
myfile.open("SPRITES.EGA");
int sprnum = stoi(temp);
cout<<"Done. There are "<<sprnum<<" sprites."<<endl;
cout<<"Reading sprites";
for (int i=1;i<=sprnum;i++)
//Get size of sprite:
sprites[i].xsize = stoi(temp);
sprites[i].ysize = stoi(temp);
//Get actual graphics data:
for (int j=0;j<=sprites[i].xsize;j++)
for (int k=0;k<=sprites[i].ysize;k++)
sprites[i].picdata[j][k] = stoi(temp);
cout<<".";
myfile.close();
void LoadLevel(int l)
//Actually, the argument passed to this doesn't do anything right now since we only have one level.
//SDL_Delay(5000);
cout<<"Loading Level..."<<endl;
myfile.open ("LEVEL01.MAP");
string temp = "";
cout<<"Getting level size...";
lx = stoi(temp);
ly = stoi(temp);
cout<<"Done. The size is "<<lx<<"x"<<ly<<"."<<endl;
cout<<"Getting level data";
//for (int i=1;i<=tilenum;i++)
for (int k=0;k<=lx-1;k++)
for (int j=0;j<=ly-1;j++)
foretile[j][k] = stoi(temp);
//cout<<temp<<",";
//cout<<endl;
cout<<".";
int main( int argc, char* args[] )
cout<<"Welcome to this demo of a 2D platformer."<<endl;
cout<<"Enter a value to delay the main loop by"<<endl;
cout<<"every time it comes around, to make sure"<<endl;
cout<<"things don't go too fast. The default value"<<endl;
cout<<"is 20. Just press enter to go to default."<<endl;
string blah="";
getline(cin,blah);
if (blah != "") {loopdelay = stoi(blah);}
if (!initSDL()) {shutdownSDL();}
LoadGraphics();
LoadLevel(1);
mainloop();
shutdownSDL();
return 0;
I know my "loop delay" thing is the dorkiest possible solution. I just didn't have time to implement a proper timer.
Thoughts, philosophical musings, anyone?
World's foremost 486 enjoyer.
