Reply 20 of 32, by dondiego
- Member
It's done, intel quark is a 486dx4 @400 mhz on a 42 nm process and has additional pentium instructions emulated in microcode. It's a SOC for microcontroller boards so the chip contains more stuff.
I think reverse engineering the VSA-100 would be very expensive.
Does the Quark include legacy chipset functions like ISA with DMA? It's not intended for compatibility the same way that Vortex86 is.
What I'd like to see would honestly be a K6-III but maybe at say 45nm, lets not get to crazy. They could quadruple the L2 to 1mb, and call it a K6-IV that would be awesome
But it would be a marketing failure. You do know it costs ruffly between 100-200k just to fab a motherboard with a developet platform. Not to mention one that would need the chipset and CPU made. My sources say it can cost upto 10bil to fab a new CPU from scratch useing 45nm or 32mn. thats including the cost of everything, pay, equipment, and R&D.
Obliviously a newer k6 would cost much MUCH less and it's already developed and what not.
wrote:But it would be a marketing failure. You do know it costs ruffly between 100-200k just to fab a motherboard with a developet platform. Not to mention one that would need the chipset and CPU made. My sources say it can cost upto 10bil to fab a new CPU from scratch useing 45nm or 32mn. thats including the cost of everything, pay, equipment, and R&D.
You do realize we're just fantasizing here. 😉
True, but fantasize right. 😎
How about a p4 at 14nm that runs at 10ghz+. Or a Piii with 4 cores per die at 45nm running at 2ghz with 1mb l2 pre core? The k6 is a dead end in manny ways. If we're going to spend billions of pretend money lets make it count. 🤣
For me a retro system reboot needs unbridged ISA slots, that is for sure. And maybe I would rather see a i440BX chipset+mainboard reboot then a CPU. With SATA controller in the southbridge, proper 50..166MHz FSB support adjustable in software. But in case of a CPU reboot it would have to be socket 370 (not Slot 1 like i suggested earlier) since I really like the tinkering options of slotkets.
wrote:True, but fantasize right. 😎
We already have that, they call it Core 2 Quad 😜
But not on SK370?
Vortex86 would be cool for DOS, If only it had the "unbridged ISA slots" I mentioned earlier.
I read on the Vortex86 Wiki that the Vortex86DX is the last one to support the ISA bus. There are some with ISA slots here.
On second thought, would this really be desirable over, for example, a (Mini-)ATX i440BX Slot 1/Socket 370 motherboard with a VIA C3 1200MHz? The VIA is also a late production low power CPU. I have one from 2006 running fine on 1,3 Volt. The wiki says that the Vortex is derived from the socket 7 Rise mP6 processor, whereas the VIA C3 comes from the IDT Winchip design.
The Vortex86 website is full of dead links (missing PDFs), and the spec sheet there is not matching the info on the wiki...
