The Boring Beige Box podcast went 404
Announcements, advice, random banter, unrelated discussion, et cetera.
Postby djukon » 2017-9-28 @ 21:19
Greetings,
Just to let everyone know that the Boring Beige Box's libsyn account must have expired and the episodes are no longer available for download. Luckily I was catching up recently and was still able to preserve episodes 15 to 22.
Does anyone else have the other episodes so we can preserve it for posterity's sake? And BTW, where should they get stored? Just in case, I'm currently backing up the episodes I have to online storage.
Thank you.
djukon
Re: The Boring Beige Box podcast went 404
Postby djukon » 2017-9-28 @ 21:35
djukon wrote:Luckily I was catching up recently and was still able to preserve episodes 15 to 22.
More luckily, I was able to recover episodes 7 through 10 as well, with no overwritten clusters. There are other partial recovered files: 5, 6 and 11 through 14.
Unfortunately, all the files are iTunes versions of the originals, which means they contain file name corrections and episode 10 even contains incorrect information in the tag (possibly due to an iTunes bug). I'll now try to recover additional files from the iPod, if luck continues on my side.
djukon
Postby djukon » 2017-9-28 @ 22:04
djukon wrote:
djukon wrote:I'll now try to recover additional files from the iPod, if luck continues on my side.
Indeed there were more files on the iPod. Episodes 6 through 14 were totally recovered. Episodes 1 through 5 were partially recovered. iTunes fortunately has the metadata stored even for listened to files, so for episodes 1 through 5, at least the metadata is recoverable (by copy-paste).
So the main question now left is, who stored episodes 1 through 5?
(edit) If you need to run a file recovery pass on your storage media, here are some clues for episodes 1 through 5, in case some file metadata is missing. They are all 64 kbps 24 kHz MP3 files.
001: Intro to Boring Beige Box; 21 minutes; 9.2 MB
002: Online Services of the Early 1990s; 44 minutes; 20.1 MB
003: IBM PS/1; 25 minutes; 11.5 MB
004: Modems; 26 minutes; 11.7 MB
005: LucasArts; 38 minutes; 17.4 MB
djukon
Postby djukon » 2017-10-19 @ 11:04
On this shared folder, you can find audio files for episodes 6 through 22, meta data for episodes 1 through 5, as well as the website's podcast list from Google's cache.
For some odd reason, Episode 22 seems to be missing the last one to two minutes. iTunes didn't download the file correctly the first time round, so my backups are based off this cut off file. I corrected some inconsistencies in the files' metadata (especially episodes 21 and 22) and added the show's small artwork/icon/logo to each audio file. Though I didn't re-listen to the episodes from start to finish, I did jump around the files and played the intro and outro to be sure the files are the right episodes and are without large missing parts/errors.
I'm still uploading the files as I post this, they should all be up in a few minutes. If anyone finds the missing episodes, or some error I didn't detect in the shared files, please let me know. Thanks.
djukon
Postby Mr_ppp » 2017-10-19 @ 12:57
Is this any use? I'm at work so can't check the files, 1-5 at the bottom
Looked again and saw you can't directly download them - tried to capture them but limited at work
https://www.mixcloud.com/boringbeigebox/
This page might have the actual files - its blocked when clicking the files because of work filter tho
https://archive.li/J0Nud
Edit: NOPE - tried it on a different connection and just redirects to the original page :(
User avatar
Mr_ppp
Postby djukon » 2017-10-19 @ 13:21
Thanks for the feedback, Mr_ppp, unfortunately it is a no-go.
Mr_ppp wrote:https://www.mixcloud.com/boringbeigebox/
Mixcloud (at least for this content) seems to be a frontend for playback, piggybacking on the files (previously) available elsewhere. In this case, they were on libsyn.
Mr_ppp wrote:This page might have the actual files [...] https://archive.li/J0Nud
The audio files weren't archived here.
djukon
Postby Mr_ppp » 2017-10-19 @ 13:46
Doh!
User avatar
Mr_ppp
Postby Mr_ppp » 2017-10-19 @ 13:49
Mr_ppp wrote:Doh!
This looks more hopeful!!!
I played a few seconds succesfully but can't listen for long to verify as at work
http://audio.textfiles.com/shows/bbb/
User avatar
Mr_ppp
Postby djukon » 2017-10-19 @ 16:52
Mr_ppp wrote:This looks more hopeful!!!
Great find! The first five episodes are there, complete, as well as some live episodes, which I hadn't heard nor stored. Only missing now are the last two minutes of episode 22, since the textfiles backup missed the last two episodes (nothing after 2008).
I'll update my shared folder with the new files in the next few days.
EDIT: I couldn't find the Talk Shoe page for the live podcast. It might have more recordings after 2008.
djukon
Postby fsmith2003 » 2017-11-16 @ 01:39
Whatever happened to this guy anyways?
User avatar
fsmith2003
Postby djukon » 2017-12-02 @ 10:29
fsmith2003 wrote:Whatever happened to this guy anyways?
I have no idea what happened to Matt Wilson. Does anyone else know?
Anyway, I've updated the shared folder with tag tweaked episodes 1 through 5, uploaded copies of the live episodes as-is from text-files (I haven't had the opportunity to listen to them yet), and minor tag tweaks to the rest of the episodes.
Summing up the state of this thread, we're still missing:
  • The TalkShoe page location (for grabbing more meta data, and possibly downloading more episodes);
  • Adding tags to the TalkShoe live episodes;
  • What happened to Matt Wilson.
djukon
Return to Milliways
Who is online
Users browsing this forum: acd2001 and 2 guests
