Win7 system will not activate.
Announcements, advice, random banter, unrelated discussion, et cetera.
Re: Win7 system will not activate.
Postby Jade Falcon » 2017-10-19 @ 13:33
No change in safe mode ether.
Its a very odd problem.
Jade Falcon
BANNED
Postby collector » 2017-10-19 @ 15:16
Does the process even show in the Task Manager?
User avatar
collector
Postby Jade Falcon » 2017-10-19 @ 15:28
collector wrote:Does the process even show in the Task Manager?
I don't think so. I'll have to take a look.
No even logs on the system to show why its not starting ether.
Jade Falcon
BANNED
Postby collector » 2017-10-20 @ 13:59
Have you tried the Windows Software Licensing Management tool (SLMgr)?
User avatar
collector
Postby FuzzyLogic » 2017-10-22 @ 02:01
Sorry I didn't see this sooner.
If the PC wasn't activated when you reinstalled using the OEM recovery DVD, then:
1. You used the wrong recovery DVD.
2. The BIOS was updated at some point and the SLIC was changed so that it no longer matches the certificate on the recovery DVD. It could even be that the SLIC markers are there, but empty.
3. HP gave you the wrong recovery DVD.
Get a tool called SLIC Toolkit and see if SLIC and certificate match. Dig around the Internet for an HP certificate (HPQOEM SLIC BPC) until you find one that matches your PC's SLIC. Disconnect your ethernet cable. Remove the product key using slmgr /upk [product key.] Reboot the PC. Install the matching certificate using this command: slmgr /ilc hpqoem-slic-bpc.xrm-ms . Add the product key from the sticker on the PC using slmgr /ipk [product key.] See if you're activated. If not, run slmgr /rearm and reboot. Check activation again.
If that doesn't work, call up Microsoft and activate it over the phone.
User avatar
FuzzyLogic
Postby Jade Falcon » 2017-10-22 @ 02:03
FuzzyLogic wrote:Sorry I didn't see this sooner.
the right recovery cd was used.
Bios was never updated.
Maybe.
slmgr /upk does not do any thing, SLMGR does not work.
Jade Falcon
BANNED
Postby FuzzyLogic » 2017-10-22 @ 02:38
Jade Falcon wrote:the right recovery cd was used.
Maybe.
Then use a retail ISO and install it with a generic key. Follow the same instructions because you still need the correct certificate.
User avatar
FuzzyLogic
Postby Jade Falcon » 2017-10-22 @ 04:18
Thats what im trying to avoid.
I dont want to take the system out of use again to reinstall everything again.
Jade Falcon
BANNED
Postby Malik » 2017-10-22 @ 05:29
Hmm... I guess there's no way out of it. You might just need to reinstall everything.
Use your CD key to download the Windows 7 ISO from here : https://www.microsoft.com/en-us/softwar ... d/windows7, and reinstall via USB 2.0 drive or CD.
I always like installing clean from retail CD/ISO.
Or keep in touch with HP, and hopefully someone who's experienced in that particular model and Windows 7 can help.
User avatar
Malik
Previous
Return to Milliways
Who is online
Users browsing this forum: No registered users and 2 guests
