First post, by BitWrangler
- l33t++
Hi folks,
I know enough about Windows Internet Connection sharing to futz my way through setting it up, on older windows versions I even used it over laplink cables which was handy at times, not sure if W7 does that. Anyway, main point of question, is it any more secure going through ICS on an updated W7 box, with say a win98 or XP machine than it would be hooking it direct to the router?
I am not sure if you just get a relatively straight through pipe, or it gets protected a bit by w7s port filtering and firewall, whatever security settings are there.
Thoughts?
