First post, by Qbix
Rank DOSBox Author
DOSBox Author
Hi,
Time based editing has been enabled, so you can correct typos and things like that.
If you need a post edited that is older, please contact a moderator.
The situation will be monitored and adjustments to the editing settings will be made.
Sorry for the inconvenience and don't panic 😉 .
Water flows down the stream
