First post, by bjwil1991
Got the following today from my parents:
Screwdriver Kit (better grip)
Mini screwdriver 4-in-1
Key finder (I can hardly remember where my keys are at), going to get more for my wallet, my other keys, and proximity badge for my office
TV Antenna
Soldering helping hands with a magnifying glass
60W Soldering Iron
Desoldering Wick (like the white-out device that you push down and pull left or right to remove mistakes)
The Clapper (turn on lights by clapping twice or thrice)
On my thrifting adventures with my brother and my mom:
Sealed copy of Ace Ventura Pet Detective on VHS
Novalogic Flight simulator game
Reply 1 of 4, by Gered
Happy birthday! 😀
Any immediate projects planned for all the soldering equipment?
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 2 of 4, by bjwil1991
Going to re-solder my Aztech sound card again and make an AV cable or two for my Commodore 64.
Reply 3 of 4, by Jo22
Just seen this thread.
I wish you a happy birthday, too! 😀
60W Soldering Iron
60W is fine. I started myself with a 220v, 60w soldering iron.
If you're going to make some soldering jobs more often, there's also an upgrade path to a regulated soldering station.
I'm using a very old Weller Magnastat TCP24 from the 1970s, which is very robust (the tip of the iron is almost unbreakable).
The reason I tell you is because these can be found for cheap from to time to time (the amateur radio folks in my place used to use them).
Also, if you're having trouble with soldering, esp. with lead-free solder, you can try to use a solder flux based on rosin aka colophony.
I think it is also available in liquid form in tubes (dissolved in alcohol; hope that's the proper English description).
It is pretty much out of common use, but less poisonous than the modern flux (it doesn't smell like dead fish).
It also doesn't cause shorts, so you don't need to remove it from PCBs.
Sounds good! I wish you the good luck for that. Please keep us up-to-date.
Reply 4 of 4, by bjwil1991
I also have flux as well (which does help loosen stubborn solder by heating it up more) in case the soldering iron won't heat up the old solder faster (my 15W iron isn't enough, and the tip is too thick) and to put the solder on the contact points that need it.
I also have tip cleaner as well, which does make the soldering iron tip shiny and last longer, plus, I use contact cleaner to get rid of excess flux.
