First post, by VLC
COULD SOMEONE HELP -
1. ive got codemasters 'music 2000' cdrom, but at install it says - 'dxsetup returns error SETUPERR_CANTFINDINF'
then doesnt install. [duh!]
- even tho my win98se 'dx-diag' prog shows no errors, an my dx-setup of version-9, works fine with all other software on my pc.
ps- the game cd's own dx-suite wont reinstall as it says i have newer version already present!
2. so i had to install it via its cdroms 'setup.exe' prog.
but after it installs ok, when i goto click its start-up icon or menu shortcut, to finally use it, all it does is just change the screen res for a few seconds, then flip back to normal, BUT nothing else!
so what do i do - as i posted this quey on their forum but got NO help at all !
Star Treking...
Reply 1 of 1, by Snover
Setup Error. Cannot find INF.
The file is probably damaged/does not exist where it should.
What INF file? I dunno. Check the Applications event viewer. (NT/2k/XP only)
Yes, it’s my fault.
