First post, by buckeye
- Oldbie
I'm agonizing over this, but just trying not to blow a wad of cash. Since I may have access to reliable internet been thinking about breaking
down and getting a "modern" pc for home. Up to this point I've been using my work pc for access to my GOG games which I just copy on
a USB stick and install on the XP rig at home. This brings me to an article in Maximum PC where they discussed buying used/refurbished
office OEM pc's and adding items like ssd drives, geforce 1050ti type graphics cards for gaming at "moderate" graphics settings.
The thing with this approach is the limitations of the proprietary power supplies/connections. Keep in mind I'm referring to not the SFF
but the mini towers at least, I like to have a bit of room to work with! The only model I've found feasible so found was dell optiplex 7010
which seems to sport a 24 pin power connection unlike the other flavors, however fitting in the actual power supply may have issues I
don't know. I wasn't going for any older than 3rd-4th generation i5 or i7 processors and they'll have a win10 os already installed. Some
of you out there I noticed are even using slightly older Xeon based systems for your "daily" rig, like to know your thoughts on this too
since there are a lot of oem workstations out there that could fit the bill too.
My "modern gaming intent" is playing Madden 2019 and Star Wars BattleFront w/o maxed out settings and of course playing the usual GOG
stuff. The lure of the "dark side" is strong - max out credit card and build a gaming beast from scratch and the satisfaction that comes with
building something yourself but I'm trying to be frugal here I guess. What are your thoughts out there? Go the OEM route or build from scratch
with a say 1000-1200 budget? Sorry for the mouthful but really need the input from you "brethren".
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
