A question about Amiga serial port usage
Announcements, advice, random banter, unrelated discussion, et cetera.
Postby Jo22 » 2019-6-02 @ 07:58
Hi everyone, I've got a quick question that I hope some of you may know an answer to..
Does the Amiga platform require RTS/CTS lines to be physically crossed in order to transmit ASCII characters (fake handshaking) ?
Currently, I'm trying to get some of the old Amiga terminal programs running in WinUAE in conjuction with an USB serial adapter.
For some reason, though, the Terminal software never sends or receives any characters.
The device that I like to connect to is attached vis TXD/RXD and GND.
A connection with HyperTerminal was established just fine.
User avatar
Jo22
Re: A question about Amiga serial port usage
Postby BushLin » 2019-6-02 @ 10:03
This page may be of some use to you
http://www.amigaforever.com/kb/13-105
I can't say RTS/CTS was a a requirement for the platform but it certainly was a common requirement of Amiga software and there are many tales of woe from cables which weren't fully wired.
Screw period correct, I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
User avatar
BushLin
Postby Jo22 » 2019-6-02 @ 10:31
Thank you! :D
So it could be as I feared..
I need to make a 3-wire null-modem with fake RTS/CTS.
(I hoped I could just use my fully-wired null-modem cable.)
Edit: Perhaps I need also fake DTR/RTS/DCD wiring, not sure..
"Null modem operation
When a serial connection is made between two computers using a null modem adapter,
the DTR and the Data Carrier Detect (DCD) lines are typically paired. This allows both ends of the connection to sense when the connection is active.
On many operating systems, including Windows, the DTR line is held low while the serial port is unused and not being controlled by any applications.
Source: https://en.wikipedia.org/wiki/Data_Terminal_Ready
User avatar
Jo22
Postby Jo22 » 2019-6-03 @ 20:34
Hi again.
I made a custom cable with RTS/CTS and DTR/DSR/DCD shorts..
Still no change, sadly. The cable works fine with HyperTerminal, BananaCom and Terminal from Windows 2.0..
But not a single one of the Amiga terminals worked. :depressed:
I tried AmigaTerm, Ahost, AmigaDisplay and Handshake.
User avatar
Jo22
Postby Jo22 » 2019-6-04 @ 06:23
.. the cable.
Edit: I adapted the cable for DE9 (DB9).
User avatar
Jo22
Postby dr.zeissler » 2019-6-04 @ 06:51
I use it for amiga-explorer. Not fast but ok.
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby Jo22 » 2019-6-05 @ 03:48
dr.zeissler wrote:I use it for amiga-explorer. Not fast but ok.
I see, so it works with real hardware, at least ? With Kick 1.3 and WB1.3 ? :)
Btw, here's a picture of AExplorer that I found - I suppose that's the right software.
- I'm trying to get these old terminal programs running with a microcontroller here..
If that works, so I thought, maybe I could use AmigaBasic with it at some point, too..
User avatar
Jo22
Postby Jo22 » 2019-6-05 @ 03:53
By the way, do you know of any other Amiga Emulators beside spin-offs of UAE or Fellow ?
I essentially need one that only has a working serial pass-trough (Fellow hasn't it working yet).
It can be incomplete otherwise.
User avatar
Jo22
Postby Jo22 » 2019-6-10 @ 09:24
Any ideas ? Please... ?
User avatar
Jo22
Postby Jo22 » 2019-6-13 @ 06:22
Hi again, does anybody know as to why I can't use my serial port ? :depressed:
Is it because I'm trying to use an USB-Serial adaptor with WinUAE ?
And are true, internal RS-232 ports known to be working with WinUAE ?
If so, can you tell me which versions you successfully use(d) ?
Or how about other Amiga OSes, like Amithlon ? Can they use serial ports ?
Any help welcome! :)
User avatar
Jo22
Return to Milliways
Who is online
Users browsing this forum: borichka, knowledge [bot] and 4 guests
