First post, by athlon-power
- Member
I know this is a forum for old computers, but LinusTechTips doesn't seem to be too keen on really helping me with any issues, lately. I know you guys are courteous enough to at least try to help, so that's why I come to bother you so often.
Anyways, this would be a classic "enable XMP (AMD version) in BIOS"- except, I can't. This is a Dell Inspiron 5676, so it's an OEM system- no BIOS options other than passwords and disabling virtualization. The system normally runs its RAM @2400MHz- that's what everything says it supports, anyways. I don't even want to push it to 3000, but I at least want it at 2400. I installed Ryzen Master, however, it won't let me adjust the speed of the memory. It's greyed out, whereas the CPU options are fully open to use. I'm not sure how I could push this RAM to 2400MHz.
One idea I had involved sticking an original 8GB memory module into it that runs at 2400MHz so that the G.Skill would pick that up, but I think the other 8GB stick would just underclock to the same 2134MHz speed as the G.Skill. I'm not aware of any software that could push this RAM to at least 2400MHz. It's G.Skill Ripjaws V, for anybody that's curious.
(Yep, this is the same system where I thought the original PSU detonated and wiped all life from the face of the Earth- which it didn't. I now have a new EVGA 500BQ PSU I'm using. But I also accidentally dropped the Ryzen 5 2600 and bent pins to an irreparable state- So I'm using the Ryzen 5 1400 again. Next paycheck, I get to buy another 2600 for ~US$170. Yay. I'm always so lucky with vintage hardware, but with modern hardware, I am much more prone to damaging it, it seems)
Where am I?
