Reply 180 of 547, by Bruninho
- Oldbie
ShovelKnight wrote on 2020-06-26, 07:40:I bet it works exactly the same as on Intel Macs with the T2 chip: you can boot anything you want if you disable secure boot, but the built-in storage is off-limits.
Gotcha. Yes and no. From what the video hinted, even if u disable it and only obviously try to boot any ARM based OS, its unclear if unsigned non Apple OS can be booted. Its the same boot process used on iOS and iPadOS. In this case, iOS jailbreak history shows that it could be done.
JOBS, Steve.
