Miphee wrote on 2020-07-11, 09:19:I recently got this freebie chinese IP camera from a friend. He never used it because he claims it's not secure.
It shows up on […]
It shows up on the wireless network as a cloudcam and it has no security added at all, not even WEP. Anyone in range can connect to it.
I tried the YCC365 Plus app it came with, it's rather simple. First I have to connect to the cloudcam in my wifi list (no password), then use a local device account inside the app to access the camera. It uses the standard admin/password scheme and it cannot be changed.
It doesn't have an admin interface so can't add a password there.
Info would be appreciated.
I have had a lot of the cheap Chinese security cameras over the years, the first thing I do is disable the wireless even if I have to open them up and remove wires and parts to disable the camera's wireless, then I only use Ethernet after that, and if the cheap Chinese security camera don't have Ethernet I just don't use them, then I disable has much has I can on the camera using the camera's own web setup, and then I put the cameras behind there own router and have a computer record and serve up the camera's video to another router and my home network, even with the setup I have it's still possible for someone to spy on you, just a little harder, I just don't trust the cheap Chinese security cameras.
