First post, by DosFreak
For those not aware of the work being done on winraid and MDL then this thread is for you.
https://forums.mydigitallife.net/threads/driv … hardware.81607/
*Login required
ACPI 2.0+ - Patched drivers to workaround STOP 0xA5 errors related to new ACPI standards […]
ACPI.SYS 6666 (from outerspace :p)
ACPI.SYS 5048 (from Vista beta)
Memory related
WinXPPAE v2 - Patches kernel and hal files to enable PAE (Physical Address Extension)
USB3 / XHCI
Kernel Mode Driver Framework 1.11 by MOV AX, 0xDEAD - Unofficial standalone installer based on the Security Update KB2864202 for Windows 8. Needed for USB3 / XHCI driver stack.
USB3/XHCI (generic) driver by MOV AX, 0xDEAD - Backported from Windows 8, requires the Kernel Mode Driver Framework 1.11 to be installed first. Includes UASP (USB Attached SCSI Protocol) support. Multilingual INF file.
Deprecated:
AMDXHCI 145 v3 with PAE patch by MOV AX, 0xDEAD - Driver patched to support Intel USB3 controllers
AMDXHCI 276 with PAE patch by MOV AX, 0xDEAD - Driver patched to support Intel USB3 controllers (based on Windows 7 driver)
Storage support (AHCI / RAID / NVMe)
AHCI (generic) driver by MOV AX, 0xDEAD - Backported from Windows 8, requires storport.sys (backported from Windows 7) and storpor8.sys from Extender, both included.
NVMe (generic) driver - Backported Windows 7 driver, requires storport.sys (also backported from Windows 7, included).
Samsung NVMe (generic) driver 3.3.0.2003 - Backported Windows 7 driver, requires storport.sys (backported from Windows 7, included).
For Intel:
RSTe 4.7.0.1117 - XP x86 (updated) - Backported Windows 7 driver, requires storport.sys (backported from Windows 7, included).
For AMD:
AHCI driver 1.2.1.402 - Windows 7 driver, requires storport.sys (backported from Windows 7), included
Make your games work offline
