First post, by antrad
Do you remember when you upgraded to dual core computers and when did you first saw the benefit in gaming ? I guess this started around 2006-2007, I was stuck with a single core processor until 2014, so I missed the party.
Reply 2 of 3, by Kreshna Aryaguna Nurzaman
leileilol wrote on 2020-08-15, 05:22:
Quake3 did have SMP support back in 1999, but that's more for dual CPUs rather (NT4 was officially supported by Q3A). Quake 4 however did have early dual-core support in an early 2006 patch...
Actually, Falcon 4.0 beat Quake 3 to it.
Kreshna Aryaguna Nurzaman.
Reply 3 of 3, by DosFreak
Jan 2001 with Quake 3
2XP3-700E@933 133Mhz bus X 7 1/4
Abit VP6
Honestly though didn't enable SMP much in Q3, FPS were higher in at 800x600 and below but didn't game at low resolutions if I didn't have to.
I did see a benefit with everything on the system since it had dual processors so anything else running on the system didn't interfere while gaming even though the games were limited to a single processor which you could change the affinity for which was nice.
Played around with UT on a dual PPro 200 sometime in 2000 but AFAIK Unreal 1 didn't support SMP.
Next processor that had multiple core was in 5-18-2007 C2D E6600, even then barely any games used multiple cores. I seem to remember Supreme Commander having support. UE3 games? Farcry 1, Serious Sam 2.
You probably need to look at 2008+ for a larger list. Mabye track when the game engines started adding support, included Vista on the game box, XBOX 360 ports, etc.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
