Reply 20 of 29, by Cyberdyne
In reality Volkov Commander is better, totally assembler programmed and smaller, faster, and have all the needed functions.
Reply 22 of 29, by gerry
modplug among others, generally windows circa 2000 software often does what I want and is stable when used as standalone applications. Anything that might need to create data compatible with newer software or go online will be forced to 'upgrade' continuously
using old software isn't just something quirky or 'hipster', sometimes there is a piece of software that one learns very well, masters even, and can actually be more productive on it than on more modern software equivalents, even when objectively the modern one has potentially more productivity benefits
its a bit like learning to race one model of car - sure the new cars are better but you are actually slower in them because you're not used to it
that's one of the reasons, if you've ever worked in offices or trained office workers, there was always a moan with a new release of their most used applications - they all new that for a few weeks the new version would slow them down while they got used to it
Reply 24 of 29, by texterted
Macromedia's Fireworks MX. It works on all my machines, 98se through to win 7 64 bit.
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Windows Home Server v1 :- Gigabyte GA-EP43, Pentium E5200, Bunch of SATA HDD's.
Reply 25 of 29, by fyw321
does emule count? it's pretty much old and not much changed through every update releases.
my favorite site stoped releasing anything with ed2k link anymore. but I just autostart it everyday with empty task list, and hope i can still share something to help some cyber stranger by doing this.
Reply 26 of 29, by Shagittarius
ZDir for all your DOS directory needs. I always rename it Z. Im so use to it I try to use that command on others machines.
    zdir21.zip
    51.93 KiB
    3 downloads
Reply 28 of 29, by winuser_pl
I use Microsoft Visual Studio 2005. Borland C++ 5.02, Paint Shop Pro 6 and the others 😁 Actually I like that software.
    120.63 KiB
    145.04 KiB
    86.88 KiB
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 29 of 29, by Oetker
winuser_pl wrote on 2021-01-19, 08:55:
I was also always a big fan of PSP 6 and hated later versions. Now I use Paint.net.
