First post, by scroeffie
hi i have found this monitor and its working perfect but the switch is not working correct on off switch
so i need a new one found one on ali but it cost 40 euro !!
i also wanted to know if svideo was possible ?
its a pal tv
all these switches have the same problem there is a small plastic pin inside that brakes fast https://retro8bitshop.com/product/crt-monitor … wer-switch-new/
http://www.glitchwrks.com/2018/07/31/hp-700-43
Reply 1 of 2, by BitWrangler
You can make a simple converter for Svideo to composite, https://www.epanorama.net/circuits/svideo2cvideo.html but svideo to RGB is more involved and a converter box may be needed.
