Here's some:
"Warning: Unauthorized transit gate activity detected. Incoming hostiles."
"Deploy wide spread, Riley take point."
"Roger, heading zero-one-niner."
"Switching to secured channel."
"New mission orders received."
"AHH! The fuel leads are jammed! I can't get loose! Cut the fuel leads!"
"What took you so long!? This place is a warzone! Clear a path to the roof!"
"Are you deaf as well as stupid!? Clear a path to the roof!"
"Greetings from the Krupp Verdan Corporation!"
"You are trespassing on private property."
"This unit has sustained critical damage. Please contact your Kurpp Veran dealer."
"Your RPV is in good repair."
