First post, by GabrielKnight123
I was putting together a socket 7 with Dos 6.22 already on the hard drive and noticed I could read 3.5 floppy disks that already had data on them but it wouldn't if there was nothing on them so I tried formatting them in dos and this worked I could format them but straight after it said "general failure reading drive A, abort, retry, fail?" I tried formatting a couple on my windows 10 PC because I knew the floppy disks and floppy drive were good and working and Kaspersky did a virus scan of the floppy and it found Virus.Boot.NYB
I tried to resolve it with Kaspersky but it said "cannot disinfect the detected object due to internal error" I guess Kaspersky cant write to the MBR of the floppy, I was able to format the floppy on windows 10 and a Kaspersky scan later it did not find the virus
Does formatting in Win 10 using a USB floppy drive overwrite the MBR? I'm now going to start a fresh and format the dos hard drive and rewrite the MBR but is there a way to "clean" Virus.Boot.NYB from the hard drive and floppies in dos as I might have to go through my other two systems a 486 and Win 98se and maybe Win XP not to mention about 6 boxes of floppy disks
F-PROT used to detect NYB as B1, but the virus was renamed in February 1996 (F-PROT 2.22) is F-PROT still the best dos virus cleaner?
EDIT: I tried a floppy that I formatted and virus scanned from my win 10 PC in my dos socket 7 build and it is reading it properly as empty but there is no error about "general failure reading drive A, abort, retry, fail?", I write protected the floppy first so it doesn't get NYB again
Reply 1 of 12, by weedeewee
GabrielKnight123 wrote on 2023-03-05, 12:27:
yes
yes
Do not ask Why !
Reply 2 of 12, by cyclone3d
So that socket 7 system is probably infected.
You need to make sure to scan every single floppy disk you have used in that system and figure out what media the virus came from.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 12, by GabrielKnight123
I just finished doing that cyclone3d all the floppies I own have been Kaspersky scanned but now I'm going to boot with a clean 98se boot disk and use F-PROT from a CD to check the hard drive and all my floppies again in case Kaspersky missed something at least I now know my floppy drives were running good
Reply 4 of 12, by Jo22
Cool! Did you know that collecting these little critters is a vintage hobby of some people?
It's a hobby inside a hobby.😄
Reply 5 of 12, by chinny22
Jo22 wrote on 2023-03-05, 18:45:
yeh but why? I can only think its part of some master plan to take over the world bond villain style 😉
Reply 6 of 12, by TrashPanda
chinny22 wrote on 2023-03-06, 09:30:
You can learn a surprising amount from these little beasts, virus creators used some exceptionally creative ways to infect machines. Its fun to dig into the inner workings of virus creation and also just as funny to load a machine up with as many as itll hold then try cleaning it before it falls over.
Reply 8 of 12, by GabrielKnight123
I finished F-Proting my hard drives and floppy disks and I have a question about F-Prot, after it found the same virus as Kaspersky "NYB" I luckily scanned it again and it found another virus in the same place as NYB "AntiCMOS.A" at the boot sector level (even though I read floppies don't have a MBR but a sector zero) is there a reason or two why F-Prot cant detect and clean all virus's at the same time?
Reply 9 of 12, by Masaw
Use my mini antivirus to clean NYB and ANTICMOS on your disks, you dont even need to boot from clean floppy disk just run VCHECK.EXE it can disable those viruses even if they are active
    VCHECK.zip
    62.84 KiB
    60 downloads
    Virus Check+ for DOS v2.0 Beta
VCheck+ Portable Antivirus for DOS
https://archive.org/details/VCHECK/
Reply 10 of 12, by wbahnassi
Disks don't have MBR, just the boot sector (sector 0 of track 0). Any proper format from a non-infected OS should eliminate the virus. For an HDD, yes you also need to clean the MBR. Either FDISK -MBR from a clean OS, followed by regular fdisk and format. Or just use a good anti-virus to avoid all that hassle 🙂
Reply 11 of 12, by mkarcher
GabrielKnight123 wrote on 2023-03-07, 06:00:
MBR and "boot sector" are two different concepts. MBR is the first sector of your hard drive. Floppies don't have an MBR. The job of the MBR is to look for the active partition, and boot that partition. "Boot sector" is the first sector of any partition (or a floppy disk, which is treated like a single partition). For floppy disks, the boot sector is directly loaded and executed by the BIOS. For hard disks, the boot sector is loaded and executed by the MBR (at least if you use a standard MBR).
Many "boot sector" viruses were programmed in a way that they can infect both boot sectors of floppy drives and MBRs of hard drives. Some AV vendors called this type of virus "multipartite".
A boot sector virus usually works by writing a backup copy of the original boot sector to some hopefully safe place, and then putting the virus code into the boot sector. The virus will install itself into the computer at boot time, and then load the backup boot sector and continue booting. To clean a boot sector virus, there are two ways: Either you can write a known-good boot sector to the medium (which is a safe choice for non-bootable media), or you can locate the backup boot sector and copy that one back to the original boot sector (which is a general method to restore any kind of boot sector. You need different boot sectors for MS-DOS and DR-DOS for example). It's possibly the F-PROT detected NYB, and recovered the boot sector backup performed by NYB, but failed to check if that floppy had multiple infections, so the backup by NYB contained AntiCMOS.A. It's not unlikely that both viruses use the same location for the boot sector backup, so trying to boot that double-infected floppy might have ended in an endless loop with NYB loading AntiCMOS.A, and AntiCMOS.A repeatedly loading AntiCMOS.A again.
Reply 12 of 12, by Masaw
mkarcher wrote on 2023-03-27, 09:35:
MBR and "boot sector" are two different concepts. MBR is the first sector of your hard drive. Floppies don't have an MBR. The jo […]
"multipartite" refers to viruses that infect executable files (.EXE or .COM or both) and MBR of hard disks and BOOT SECTOR of floppies...it used to be that way until sometime in 2005 Kaspersky came up with it's own well defined virus naming standard (most AV uses CARO naming standard). viruses which only infect exec files and MBR of HDD but doesn't infect boot sector of floppies are not "multipartite" like in the case of "Virus.Boot-DOS.Predator.2424", unlike "Virus.Multi.Junkie.1027" which also infects BOOT SECTOR of floppies.
"ANTICMOS.A" and all variants doesn't save the original MBR of HDD when it infects, so it's unlikely that it will be caught up in a infection loop with NYB.A and besides, NYB is stealthy so not likely be loading each other, that's the reason why AVs can remove NYB and not ANTICMOS since it cannot find the original MBR
