First post, by MiNiDOS
MiNiDOS 2024 Release 0.01
MiNiDOS is an MS-DOS distribution with the following three aims:
1) Maintains backwards compatibility so that you can run all former DOS
software without issues. Components have been carefully chosen to
follow this route.
2) Keeps its business in an incredibly small and portable shape. Tiny
programs are much more convenient for deployment on vintage storage
media which is more often than not, restricted by space limitations.
So for this particular purpose a 1.44 MB (IBM DOS formatted high density
floppy disk size) has been selected as a boundary.
3) Attempts to be the ultimate MS-DOS 6.22 Swiss Army knife. A great
deal of effort has been put in order to pack the relevant stuff
to carry out the most common user operations, modernizing whenever
the possibility arises, without of course compromising the above two
stated objectives of this MiNiDOS distribution.
MiNiDOS Main Features
1 Multiple boot menu options for improved backwards compatibility
2 Command-line auto completion
3 Command-line scroll-back buffer
4 Full clipboard support in DOS
5 Long file name support
6 FAT 12, FAT 16, FAT 32, exFAT, NTFS and HPFS file systems
7 Drivers for FireWire, USB, CD-ROM, DVD-ROM, PCMCIA and CardBus devices
8 Universal sound card driver that offers an all-in-one solution
9 Generic mouse driver with wheel support
10 RAM support beyond 64 MB (up to 4 GB)
11 Big resizable RAM drives up to 2 GB in size
12 Conventional RAM available to run most demanding MS-DOS memory games
13 Powerful diagnostic, repair and maintenance capabilities
14 Minimalistic text editor for regular use
15 Graphic User Interface for compressing files in RAR format
16 RAR, ZIP, ARJ and LZH archive decompression has been integrated
17 Executable file compression on the disk's contents
18 Disk image creation and file extraction
19 Intuitive file manager that follows the popular two panel paradigm
20 Serial and parallel port communication programs
21 VirtualBox shared folders are mountable on-demand
22 Easy to use hard drive preparation and system installation tools
23 Power management including CPU slowdown and several associated commands
24 Numerous utilities which add more power and flexibility to your system
25 Many commonly used external MS-DOS commands
26 A robust and stable system
27 Unparalleled compatibility
28 Available for general consumption, for everyday use
29 There is much more to MiNiDOS than meets the eye
MiNiDOS 0.01 2024 is available for download at REMOVED
Reply 1 of 20, by CoffeeOne
MiNiDOS wrote on 2024-02-02, 17:48:
MiNiDOS 2024 Release 0.01 ========================= […]
follow this route.
MiNiDOS 0.01 2024 is available for download at archive.org
1st of April?
But good one!
Reply 3 of 20, by DosFreak
Removed the link on where to acquire software. I don't have time right now to look through the files so better safe than sorry.
Make your games work offline
Reply 4 of 20, by HandOfFate
Possible license issues aside, it's an impressive collection of features for the size. Did you use any tricks to save on space?
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 5 of 20, by MiNiDOS
HandOfFate wrote on 2024-02-02, 21:25:
Thanks.
I used mostly PKLITE as it is 8088 compatible, and UPX on 386+ files .
Some files are not suitable to compression due to their nature. So I always had to balance features vs available space, which was one of the biggest challenges.
Reply 7 of 20, by rasva
I came a bit late when the link for the attachment was deleted already, but managed to find it somewhere else, so I could look at it.
Wow, a lot of work is behind this. Some of the utilities I did not know until now.
I already created my own resurrection floppy based on it, by only replacing some things I do not need by some thing I use (zip file transfer for example)
Reply 10 of 20, by BitWrangler
Yes, I have also made my own boot floppy.
Reply 11 of 20, by MiNiDOS
ajacocks wrote on 2024-02-21, 14:49:
Really interesting project! […]
Do you have a website where we could read about the effort that went into this?
Thanks!
- Alex
Hi Alex,
I don't have a website for this project. The idea was that discussion could take place on forums, which encourages participation and helps to increase the available knowledge base in a public form with a wider audience. I was thinking of doing a Youtube video explaining all features and reasoning behind some design choices in detail, but time is an evil tyrant, and ultimately I was hoping it would eventually get picked up by one of the many retro Youtubers so they can both profit from the audience they may have and simultaneously provide a service in the shape of knowledge as exchange.
Anyway, as mentioned in some of the above posts you may find MiNiDOS in both the old dos Russian and internet archive sites.
There is also a lengthy text document included in the archive which gives plenty of information on MiNiDOS. I am attaching it to this post, in case you have skipped it.
Regarding the origins of MiNiDOS:
I have been a DOS user during its prime time back in the 90's. I currently have several different PCs and various different emulation systems. So I started building a single boot disk for all these machines I had, and started this journey about a year ago. Since these systems are quite diverse from the hardware point of view, I needed a generic/universal updated setup that could be as compatible as possible with almost all vintage DOS software. So I slowly started building it from the most basic concepts towards the most essential add-ons.
About 5 months ago, I already had a decently working build (so I declared the alpha state finished). Then I started to immediately and continuously tweak it, in order to push its limits. By this time, I started a revision control system and a changelog to keep steady track of development which eases the work flow. I built 54 beta versions and 1 release candidate (which is the one you have available right now).
I thought and hoped that since I spent so much effort making this project, it would be counterproductive not to share it with others that may be looking for something like this. It felt selfish for me to keep it to myself. Also others may most likely find improvements and by pointing them out may help me to eventually polish it further.
If you feel there is something else I can assist you with regarding MiNiDOS, I am happy to help whenever I can.
MINIDOS.TXT
42.06 KiB
55 downloads
MiNiDOS 2024 Release 0.01 - README
Reply 12 of 20, by ajacocks
Very cool, thanks for the explanation!
It definitely is a very useful and interesting project, and I really appreciate you sharing it with us.
If you would like, I can do a video on my tiny YouTube channel and show it off. Is there anything in particular that you would like me to highlight? I can also tell friends of mine, that have larger channels, and see if they are interested in talking about MiNiDOS.
You might want to post your information on the Vintage Computer Federation forum, as well. I’m the admin there, and we definitely appreciate content like this. We’re not as DOS-focused as Vogons, but there are lots of vintage PC fans there, as well.
And, by the way, the readme that you supply is _really_ good. And I will definitely invoke your spirit, as directed. 😉
- Alex
Reply 13 of 20, by MiNiDOS
Thank you Alex for your genuine interest, friendly and helpful response.
I would be more than happy if you could share the existence of MiNiDOS and not only do a Youtube video yourself but propose others to do the same. Just feel free to approach the video, as you would like. I have the firm belief that different voices and views on any subject are always valuable.
I will be shortly registering on the Vintage Computer Federation forum as you suggested.
Reply 14 of 20, by analog_programmer
Ok, it supports FAT32 partitions through some DOS driver, but can this custom version be used on HDD bootable FAT32 partition i.e. as main OS?
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 16 of 20, by analog_programmer
I only read "main features" from the text file and also in the very same text file I saw that "command.com" is taken from you-know-which-DOS v.6.22 and so it doesn't support FAT32 natively. I was wondering if this custom DOS can somehow access FAT32 active boot partition to boot itself properly before any 3rd parity FAT32 driver was loaded. Thank you for not giving me any simple no/yes to my very simple question.
P.S. RTFM... Ok, I'll pass.
Reply 17 of 20, by MiNiDOS
analog_programmer wrote on 2024-03-06, 21:54:
I only read "main features" from the text file and also in the very same text file I saw that "command.com" is taken from you-know-which-DOS v.6.22 and so it doesn't support FAT32 natively. I was wondering if this custom DOS can somehow access FAT32 active boot partition to boot itself properly before any 3d parity FAT32 driver was loaded. Thank you for not giving me any simple no/yes to my very simple question.
My simple intention is to encourage you to read the documentation as it was made for that purpose, especially the FAQ section which directly answers your question.
Perhaps it is my fault for not understanding that people don't want to read documentation any more and expect instant gratification.
Reply 18 of 20, by HandOfFate
I have to say that I'm using the disk quite a lot on VMs, mainly for "VBSF" (VirtualBox Shared Folders) but some of the other tools came in handy too.
Reply 19 of 20, by MiNiDOS
I have to say that I do use the VBSF a lot for MiNiDOS development. It makes things extraordinarily smoother.
BTW, I am already working on an update with a few fixes, but more importantly, lots of updates, improvements and additions.
