Reply 400 of 405, by mockingbird
I have an update to my issue.
If I run "DOSMID /COM1 TEST.MID", I get output to the MT32-Pi with it connected to the serial port...
But if I run "DOSMID /MPU=330 TEST.MID", I get nothing.
I also tried setting SOFTMPU to port 320 and DOSMID on the same port, but nada.
Next, I am going to attempt to remove my soundcard to see if it's blocking SOFTMPU from working properly.
EDIT: Nope. Removing my ES1688 did nothing.
