DOS MPU 401 intelligent mode TSR emulator/driver - does it exist?
Forum for discussion of bugs, code, and other aspects of SoftMPU.
Postby cypher » 2013-6-02 @ 19:38
Hi all,
please, I am wondering, if there exist some DOS TSR program, that can emulate the intelligent MPU 401 mode on some MPU 401 only UART compatible device.
I have just the MPU 401 UART mode compatible device, so no program that uses the 401 intelligent mode works :-(.
I am talking about real vintage hardware (Not an emulation like DOSBOX) and DOS environment.
I have found, that there is a patch for old Sierra games, which seem to emulate the intelligent MPU 401 mode on SoundBlaster MIDI port (220,240,260 or so ports).
In my case, I need something similar, but for UART MPU-401 device (not for SB MIDI port).
Thanks a lot for any help. :-)
cypher
Re: DOS MPU 401 intelligent mode TSR emulator/driver - does it exist?
Postby bjt » 2013-6-18 @ 10:28
SoftMPU 1.0 has been released and now supports more 'intelligent mode' games (e.g. Gateway, Laser Squad).
Fixed link here: viewtopic.php?t=36023
User avatar
bjt
Postby badmojo » 2013-6-18 @ 22:11
Fantastic work!
If it's broke, then fix it!
User avatar
badmojo
Return to SoftMPU
Who is online
