First post, by bjt
Short video of the serial output feature in action.
http://youtu.be/p3qCIe0TmtQ
Reply 1 of 16, by keropi
That is indeed an AMAZING feature/breakthrough, kudos!!!!
But why is the SB still needed for this? Isn't the serial virtual mpu a separate device?
ps. still having plans to "overlay" on a real mpu to get rid of the annoying buffer overflow errors with the old mt-32?
cT89QGt.gif Amstrad PC7486SLC-33 wanted , click me for AmiBay ad!
Reply 2 of 16, by bjt
SB's not required for serial output unless you want to run the Intelligent-mode titles that need interrupts (e.g. Gateway).
So for Monkey Island etc. you would only need to specify /output:com1.
Yep still planning to fix /DELAYSYSEX with Roland MPU before release.
Reply 5 of 16, by Great Hierophant
Unfortunately, no Roland MT-32 or compatible synthesizer has a serial mini-DIN style interface, only a MIDI DIN interface. I suppose if you had a SC-55mkII or other unit with a MIDI THRU, could you direct the MIDI data stream to an MT-32 via that route? I only have an SC-55ST like bjt, which does not implement a MIDI OUT or THRU.
Reply 6 of 16, by keropi
I wonder if this simple adapter can be used: http://www.cinetix.de/interface/tiptrix/midi2rs.htm , any idea if this works?
Reply 7 of 16, by bjwil1991
keropi wrote:
I wonder if this simple adapter can be used: http://www.cinetix.de/interface/tiptrix/midi2rs.htm , any idea if this works? […]
Ooh, that looks fancy. Wish I had soldering skills and those parts... That would be great for testing and trying out with my Roland MT-32.
Systems from C64 to FX-6300.
Reply 8 of 16, by Great Hierophant
I had no idea that with two resistors, you could turn the TTL-signaling based RS232 into a current loop based MIDI signal.
Reply 9 of 16, by bjt
Unfortunately the baud rate won't be right without a more complicated adaptor. Another option is to change the crystal in an existing serial interface.
According to Wikipedia the MU-series will retransmit from RS232 to MIDI too.
Reply 10 of 16, by NJRoadfan
This is basically what Apple's MIDI adapter for the Macintosh/Apple IIgs does. The difference is the Zilog SCC chip driving the serial ports can do the 32kbps required for MIDI. I think the Amiga can get away with a simple adapter too.
Reply 11 of 16, by raymangold
After reviewing what can be done for direct MIDI to serial, yeah a baud rate converter would have to be implemented somehow. And potentially a memory buffer. Unfortunately I don't have the experience to design something like that.
I might see if I can wire up serial to MIDI with some modded serial cards later (that is perfectly easy to do).
Reply 12 of 16, by matze79
really great work, now my 386SX Laptop has MIDI Sound 😀
So i can get now a small Wavetable Module and wire it directly to Serialport.
Co2 - for a endless Summer
Reply 13 of 16, by RockstarRunner
Question:
Is it the case that games using Dos Extenders (e.g. DOS4GW) such as Doom & Duke 3D will not work with SoftMPU in Serial Midi mode?
Background:
So I got hold of a little industrial all-in-one pc board, and have been experimenting with setting it up as a Dos machine for classic gaming.
I followed the schematics and built a serial to mini-din 8 cable, as this was the only option I have for connecting this pc to my midi module, a Roland SC-55mk2.
The pc has a built in Soundblaster 16 compatible device at 220/7/1, and I initialize softmpu with the following command: softmpu /sb:220 /Irq:7 /mpu:330 /output:com1
It starts up ok and finds the devices. Tetsing with Megamid and games like Monkey Island work fine. Tetsing Doom I get no music, just sfx, and Duke 3D setup tells me it cannot find an MPU-401.
Reply 14 of 16, by bjwil1991
Some games I believe (could be wrong) use the physical MPU401 port on either the Sound Card itself or a Roland MPU401 or compatible device. Wish I had a MIDI to Serial adapter for my Retro PC, but alas, it has no serial port on it and neither does my Roland SC-55 (non mkII), but my Yamaha TG100 does though. If you installed NHL Hockey 95 on your computer with the Roland MT-32 as an option for the music, it'll say the same thing: no MPU401 card available.
Since the command you typed in is correct, honestly, I cannot figure out how to run Doom with the MIDI to Serial adapter.
Reply 15 of 16, by RockstarRunner
After posting the question, I found some more threads here that basically confirm SoftMPU only works with real mode software. I actually have an MPU-401 intelligent clone isa card I could use, but don't have any way to connect it to this little PC I got without using a PC/104 ISA adapter (e.g. Acrosser AR-B1052), and i've only seen those for ridiculous money 🙁
Reply 16 of 16, by gdjacobs
You might be able to adapt the HardMPU design for the PC/104 form factor and build it up on a stackable breadboard or even a protoboard with a ribbon cable expansion.
