SoftMPU - Sound Blaster Pro 2 - Game compatibility may be reduced
Forum for discussion of bugs, code, and other aspects of SoftMPU.
Postby thierry » 2015-9-29 @ 13:19
Hello people!
Im a question ,
" The optional /OUTPUT:SBMIDI switch forces Sound Blaster MIDI to be used. This mode is intended for use with the Sound Blaster Pro 2 and other sound cards without a hardware MPU-401 interface. Game compatibility may be reduced. "
in that sense decreases compatibility games in a sound blaster pro 2, I want to buy an MT 32 and I want to try the games, but I wanted to know that limitation will have, thanks!.
thierry
Re: SoftMPU - Sound Blaster Pro 2 - Game compatibility may be reduced
Postby jesolo » 2015-9-29 @ 16:07
Refer to this link for a list of supported games and which games will be impacted if you use the /OUTPUT:SBMIDI switch: https://github.com/bjt42/softmpu/wiki
Essentially, any Intelligent Mode game, that requires MPU interrupts, won't work with this setting.
If you do want to play any of these games, then I suggest you rather obtain a sound card which does have a UART MPU-401 MIDI interface (there are plenty Sound Blaster Pro II clones that does have a UART MIDI interface).
User avatar
jesolo
Postby vetz » 2015-9-29 @ 16:45
Any game that runs with an DOS memory extender won't work, so you're limited to real mode games.
User avatar
vetz
Hardware Mod
Postby thierry » 2015-10-01 @ 14:02
Thanks people , I'll end up using a Sound Blaster AWE GOLD, I guess I will have a better compatibility after reading the wiki, thank you!
thierry
Return to SoftMPU
Who is online
