SoftMPU crashes EMM386
Forum for discussion of bugs, code, and other aspects of SoftMPU.
Postby TritonII » 2016-9-26 @ 16:15
Hello all, I feel like I've made a mistake which will be obvious to all except to myself, but...
Whenever I try to run SoftMPU I get a "EMM386 Unrecoverable privileged operation error #09" error, which crashes DOS.
I'm using a YMF724 in Win98SE Real Mode DOS with PC/PCI.
My question is, what is the most minimalist CONFIG.SYS and AUTOEXEC.BAT required to run SoftMPU? I think I must be setting up the wrong high memory parameters...
I know that to get YMF724 sound working in DOS, I need in AUTOEXEC.BAT at a minimum
SET BLASTER=A240 I7 D3 P300
C:\PROGRA~1\YAMAHA\YAMAHA~2\SETUPDS.EXE /s
I don't need anything in CONFIG.SYS and I get PCM and FM working in everything. That's great so far!
But to get General MIDI working in DOS I added the following to CONFIG.SYS
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
I also added to AUTOEXEC.BAT
C:\SOFTMPU\SOFTMPU.EXE /SB:240 /IRQ:7 /MPU:300
But that just results in the aforementioned crash at launch. Even if I remove that line from AUTOEXEC.BAT and run SOFTMPU manually I get the same crash. I've played around with LH but it doesn't seem to make a difference.
What am I missing here? Thanks.
TritonII
Re: SoftMPU crashes EMM386
Postby TritonII » 2016-9-27 @ 16:45
Alright I think I solved it...
Seems that either EMM386 or SoftMPU really hate INTA# with the Yamaha sound loader but don't mind S-IRQ.
TritonII
Postby elianda » 2016-11-17 @ 13:54
It is really interesting that the IRQ logic works with PCI cards at all.
Retronn.de - Vintage Hardware Gallery, Drivers, Guides, HQ Videos.
Youtube Channel
User avatar
elianda
Postby dr.zeissler » 2016-11-17 @ 14:02
Real-Dos-Mode means shutting down win98se to DosMode? ok.
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Return to SoftMPU
Who is online
