First post, by robertmo
- l33t++
would it be possible to add a fake refresh rate reported to games
Redguard somehow doesn't want to generate more fps than refresh rate.
even worse:
when it is able to generate more it just slows the game down to slow motion.
core i5-3450 get about from 130fps to over 200fps
i guess i5-12600 will get from 230fps to over 400fps
maybe there are some monitors that are able to set over 400 Hz in some low resolutions.
but would be nice to be able to play on a 4K TV in 30Hz.
so would it be possible to add a setting somehow to report fake 500Hz to the game while using a 60Hz monitor?
