First post, by angel_x
Hi, I am wondering if this is a known issue where videos aren't working / won't be displayed?
Unless if there is a proper way to set this up?
I can hear the intro's music though; but everything is just blank.
I can see something when the video ends and the title screen appears.
Everything else works great, only the video part is just blank.
Thanks.
Reply 1 of 3, by Dege
What if GeneralExt\EnableGDIHook is enabled (and ddraw.dll is also copied to the game folder)?
Reply 2 of 3, by angel_x
Dege wrote on 2022-04-28, 14:22:
Sorry how I do enable those? I don't see those options.
Also, I copied all 4 dlls from MS/x86 folder including the one you mentioned.
And for an update, I just realized that the video is indeed playing but it is not centered.
I was able to see the video when I try playing it in window mode with lower resolution, and the video sits at the top corner of the screen.
Tried many options but nothing seems to center the video nor scaled up the video to be fullscreen like back then when playing in DOS.
Reply 3 of 3, by Dege
Right click on the CPL window somewhere, and enable all config sections from the popping up context menu.
Or, you can edit the config INI file manually.
