SparkTR wrote on 2023-09-26, 02:36:
Are you talking about DLSS 3.5 frame generation? If so even that doesn't work for games that are locked to 30FPS. It needs a baseline of 50-60fps and the AI generated frames make it feel like 120FPS+.
Yeah, I didn't want to elaborate on it, but... frame generation is quite a new feature that came along with DLSS 3.0 and RTX 4k series and is being exclusive for that series of GPUs. Version 3.5 had to be delivered for all RTX series(unlike 3.0), but frame generation being still exclusive to only 4k series still. FSR 3 gonna provide frame generation for any GPU.
mitradis wrote on 2023-09-25, 23:58:
This requires out-of-the-box thinking.
I didn't check other games but this one and it has FPS locked for a reason. What you want to achieve is game running in 30 FPS still but you get 60 frames per second by adding some generated frames out-of-the-box so it does not affect gameplay. It's like you want to alt-tab 30 times a second and while alt tabbing you would see image that would connect to the other ones in game before and after alt tab. Frame generation is AI trained on game engines so it can figure out what's going on and create fake frames(which ain't perfect). They didn't train it for old games for sure and it's an option within the game menus. Even if it would be possible to generate fake frames for old games with frame generation you would end up with hard 30 FPS lock at the end, and if you would use patch to unlock frames you would get speeded up gameplay with perhaps some fake frames instead of real ones.
