First post, by emanuelect
Hi, sorry if I speak badly, use google translator.
The game does not allow high resolutions, and dgvoodoo by an error in the menu.
  How can I fix it?
Reply 6 of 13, by Dege
Which version of dgVoodoo are you using?
I tried this game with dgV 2.54 and it works.
It's true that it only works with default CPL settings, with 'Unspecified' scaling mode. So, upscaling the resolution and such won't work because this game doesn't like when its window get resized, etc.
(Altough the game worked for me even natively, on Win10).
Reply 7 of 13, by emanuelect
Now I'm using version 2.54.
I needed dgvoodoo to increase the resolution, because 640x480 looks bad.
These are the settings.
    40.12 KiB
    40.45 KiB
Reply 12 of 13, by ZellSF
emanuelect wrote:
OCG, i solved by modifying the exe, try it.
That works for me at least:
214.36 KiB
Though if I wanted to play this game I would probably just emulate the PSX version. The PC version just looks to be the PSX emulated version anyway: you'll see plenty of the kind of 3D rendering artifacts you would expect from a PSX in this port and no texture filtering (forcing with dgVoodoo2 results in more artifacts).
Reply 13 of 13, by stranno
ZellSF wrote:
That works for me at least: […]
IIRC Bug's Life (or maybe Toy Story 2, cant remember) have the Playstation IDS inside the disc. Not the discs but the IDS in a dummy file.
Lots of games from those days had a launcher with options like z-buffer or texture filtering. Options that dont make sense for PC but they have a lot of sense for Playstation, a console that lacked all of those features as well as many more.
Edit: Here's an example of Fighting Force. Z-buffer, perspective correction, bilinear filtering, maybe fog. That sounds like PS emulation for me.
