dgVoodoo 2 for DirectX 11
Reply 3100 of 3949, by ZellSF
Frogger: The Great Quest is a lazy PS2 conversion that's limited to 640x480. Resolution forcing works, but breaks menus (options menu and name entry). Exiting the options menus crashes the game when running dgVoodoo2 (regardless of resolution settings), but not natively.
549.81 KiB
Ace Saga: The Lament of a Raven, despite its problem of being a bit too full of Korean text looks like a surprisingly decent RTS. It works flawlessly in dgVoodoo2 and even resolution forcing works (the game is usually limited to 1024x768 with bad UI scaling). Weirdly enough it needs the "Disable8And16BitModes" compatibility flag or Windows will automatically use the "DWM8And16BitMitigation" flag and you really don't want that. I say weirdly because no other games run with dgVoodoo2 manages to trigger this.
1.19 MiB
Disney's Mickey Saves the Day. Nothing to say here. Works flawlessly, resolution forcing works flawlessly (it's a 640x480 only game):
1.62 MiB
Fur Fighters works great with resolution forcing though it supports up to 1600x1200 as is. If 32-bit zbuffer is not specified in game options it will look really bad. Forcing resolution creates lines in some 2D UI elements (the kind you would expect from forcing resolution/AA, not glitches).
771.34 KiB
Lucky Luke: On the Dalton' Trail works perfectly with resolution forcing (640x480 only game), the Glide render works too, but pictured is the Direct3D render.
691.39 KiB
End of Twilight just exits silently, no error or anything. Works natively. Demo here: http://www.gamepressure.com/download.asp?ID=930
Nelson Piquet's Grand Prix Evolution just throws an error message "The device driver data/drivers/d3d.vd reports some errors". Works fine natively.
Reply 3101 of 3949, by ZellSF
The Lord of the Sea, a Korean Warcraft 3 clone seems to work perfectly. Fonts are missing but they're missing natively too, probably due to me not having Korean fonts installed. Resolution forcing works, but you can already get 1600x1200 by editing an ini file. Still nice to be able to go higher I guess:
1.46 MiB
The Land Before Time: Big Water Adventure is another game that maxes out at a fairly high 1600x1200. Works perfectly in dgVoodoo2 with resolution forcing:
665.7 KiB
Disney's Tarzan, a Glide game, seems to work perfectly with resolution forcing:
543.4 KiB
Drakan: Order of the Flame. I was going to try this again earlier but forgot it, I couldn't get the mouse cursor working, I think UCyborg mentioned that "Fast video memory access" affects this. So I tried again now and what do you know, Drakan: Order of the Flame does work perfectly. Resolution forcing also works (and is needed since bad UI scaling), but non-integer scaling, texture filtering overrides and antialiasing makes text look bad. Though for antialiasing you can obviously just downsample and/or use post-processing antialiasing. Screenshot is without AA though:
250.27 KiB
Kao the Kangaroo works perfectly, but also has perfect high resolution support out of the box so no need to use dgVoodoo2 for resolution forcing.
Millenium Racer Y2k Fighters works perfectly too. It doesn't need resolution forcing since it supports high resolution perfectly, but it won't work at all without dgVoodoo2 (well it has both D3D and Glide renders so you could use another Glide wrapper).
Nightmare Creatures works perfectly. Resolution forcing works too, but the game natively supports high resolution anyway. Though you probably need dgVoodoo2 to make that work anyway (without dgVoodoo2 it only reports 0x0 as the only available resolution).
Astérix: The Gallic War is another game that just crashes. Doesn't run natively either (complains about failing to get mouse then crashes). WineD3D crashes like dgVoodoo2. DxWnd runs the game OK.
Diduz wrote:
Hi, I can't download v.2.54 from the website. Browsers tell me the file is "dangerous" 😵
Seems a false positive to me. Should I deactivate my firewall?
BTW, this thing is great, I'm managing to play Donald Duck Goin' Quackers vith v. 2.53 almost without issues (except for fmvs, which don't run at all), so thanks a lot. 😀
FMVs should work, they do on my computer. Also the game looks pretty great with resolution forcing. It's included options for resolution are "low", "medium" and "high". With dgVoodoo2 resolution forcing it only determines the size of movie clips (set resolution to "low" for best results). "Disable Alt-Enter to toggle screen state" must be on or the game will go into window mode during startup.
766.7 KiB
Reply 3102 of 3949, by ZellSF
dgVoodoo2 has some weird idea about how Praetorians' menu should look:
13.36 KiB
Here's how it actually should look:
245.05 KiB
Demo here: https://archive.org/details/PraetoriansDemo
Infestation looks nice with forced resolution (by default it's limited ingame to 1024x768):
905.27 KiB
No complaints about Evil Twin: Cyprien's Chronicles' either. Resolution forcing works (this again is limited to 1024x768, though there is a way to hack higher resolutions if you like hex editing):
965.4 KiB
Now this is nice, Every Extend one of my favorite little timewasters runs perfectly with resolution forcing, by default it just runs at 640x480, dgVoodoo2 makes for a very noticeable improvement:
484.13 KiB
Reply 3103 of 3949, by ZellSF
More games that just work. First Army Men RTS, by default limited to 1280x1024, which might be intentional. It reads my custom resolutions so obviously it enumerates resolutions from Windows, but stops at 1280x1024 for some reason. Well even if it had worked at higher resolution it has bad UI scaling and would need dgVoodoo2 anyway. There's some extremely minor glitches introduced by resolution forcing.
1.21 MiB
The I of the Dragon. Only tried the demo here and couldn't check what resolutions it supports since the resolution selector was broken. That said I know the game has bad UI scaling and not any longer with dgVoodoo2's resolution forcing.
1.76 MiB
Etherlords is a game that's limited to 1024x768 with bad UI scaling. Sadly it seems to render the mouse cursor separately so with dgVoodoo2 and resolution forcing you get artifacts when moving the cursor. Still worth considering it over dealing with low resolution and bad GPU/monitor scaling though. Forcing antialiasing, texture filtering or non-integer scale resolutions is a bad idea here. Also for some reason dgVoodoo2 insists on running the opening videos windowed.
1.28 MiB
Etherlords 2 appear to be running almost the exact same engine (it's a pretty different kind of game though), so no difference here.
1.98 MiB
Idinaloq looks pretty good, I think it's a 512x384 game by default actually. Sadly I get framerate drops whenever a new 3D model is loaded (I think). This also happens in WineD3D so it's probably not rendering related. I need to try it on a faster computer to see if it makes a difference.
1.1 MiB
Reply 3105 of 3949, by ZellSF
Hogs of War has... problems:
79.32 KiB
It actually looks the same natively. ddrawcompat gets it correcty which makes me think it's ddraw related in some way. Here's how it should look:
94.72 KiB
Pac-Man Adventures in Time also has issues:
111.66 KiB
Here's how it looks natively:
117.57 KiB
Demo here: https://archive.org/details/PacDemo
It would have been nice if Hitman supported resolution forcing since the widescreen mod is only available for the D3D render and the UI is too tiny in 640x480 so you can imagine how easy it is to see at 4K. Unfortunately there's some pretty bad artifacting when forcing resolution here:
384.46 KiB
Jurassic Park: Operation Genesis, Shadow Man and The Thing seemed to work perfectly, but they have proper high resolution support out of the box so no sense forcing resolution.
Wildfire crashes when loading levels with dgVoodoo2. It works natively and with WineD3D. It has a demo, but I couldn't get the demo to work at all.
Reply 3106 of 3949, by ZellSF
Homeworld has some focus issues, improved a bit if you skip the intro video. Changing render or resolution ingame doesn't work (works natively though). You can just set render and resolution via regedit. Once you get to the menu everything's good, resolution forcing works great (good thing too as this has bad UI scaling) as long as you don't force antialiasing or texture filtering.
365.53 KiB
Gangland works perfectly. Has bad UI scaling so resolution forcing working is nice, but it is not flawless as it has some minor artifacting.
932.91 KiB
Asterix Mega Madness works flawlessly. Resolution forcing works, but breaks fullscreen (nothing you can't fix with Borderless Gaming). The game does natively enumerate all resolutions, but higher resolutions (haven't checked how high) breaks graphics.
980.6 KiB
Micro Commandos is obviously misbehaving. 2D elements are flickering and wrong:
118.54 KiB
Natively (and with WineD3D) looks like this:
124.38 KiB
Reply 3108 of 3949, by ZellSF
Massive Assault works great as long as you select software mouse (hardware mouse is invisible). Resolution forcing works too (helps with UI scaling). Antialiasing and texture filtering is another matter, so in this screenshot I've used ReShade's SMAA shader:
1.37 MiB
Sequel, pretty much same thing (though for some reason it refuses to work with dgVoodoo2 on one of my computers):
1.34 MiB
Project Nomads works, but mouse cursor is missing in menus (no big deal really). Resolution forcing works (by default game is limited to 1024x768, but you can hex edit a dll to get higher resolutions):
1.23 MiB
Stratosphere: Conquest of the Skies has problems, some polygons are just way too large:
90.34 KiB
I would fine a comparison image but this pretty much happens randomly (but frequently). Works fine with DxWnd (well it doesn't have this issue, but different problems). Demo here: https://archive.org/details/STRATDemo
Reply 3109 of 3949, by ZellSF
Die Slave works with resolution forcing (usually runs at 640x480):
437.35 KiB
Dungeon Siege works great. Resolution forcing (needed because UI scaling and supposedly higher resolutions crash) has some minor text artifacts and artifacts when moving the cursor. Antialiasing breaks shadows, so here's ReShade+SMAA:
1.32 MiB
Kult: Heretic Kingdoms works and so does resolution forcing, but little benefit since there's very few tiny 3D models and huge 2D backgrounds. The ugly seams here are not the result of resolution forcing, it looks that way natively too:
1.22 MiB
The Summoner is being oddly specific about calling dgVoodoo2 a Voodoo card and refusing to initialize the D3D render. Maybe the D3D render just looks to see if the card is called *Voodoo* and errors out if it does?
12.87 KiB
Well if that's the case, maybe just hex edit the exe and rename any references to "Voodoo"?. Works pretty great:
794.04 KiB
No clue if resolution forcing is needed. There's a fan patch that allows arbitrary resolutions but I don't know how it behaves. The demo fails to find dgVoodoo2 entirely (but works natively). https://www.fileplanet.com/56714/50000/filein … o/Summoner-Demo
Reply 3110 of 3949, by ZellSF
MechCommander 2 works, resolution forcing to high resolutions (where Windows DPI scaling comes in) seems to crash loading screens. The game is by default limited to 1280x1024 with bad UI scaling. Antialiasing and texture filtering breaks 2D elements, so again ReShade+SMAA:
393.02 KiB
Reply 3111 of 3949, by Shing
ZellSF wrote:
DDungeon Siege works great. Resolution forcing (needed because UI scaling and supposedly higher resolutions crash) has some minor text artifacts and artifacts when moving the cursor. Antialiasing breaks shadows
Do you check the performance too? I remember trying DS1 with dgVoodoo and i had horrible FPS... I didn't test it with the latest version though.
Reply 3112 of 3949, by ZellSF
Most of the games I posted about I tested on a GTX680/i7-860 system the rest on a GTX1070/i7-4790. I tested all of them with vsync disabled (which causes performance problems in some games in dgVoodoo2). Dungeon Siege I tried on the slower of the systems and it ran at 70-90 FPS.
Only game I noticed had performance problem was Idinaloq, and that did turn out to be computer specific. I want to figure out why but that's hardly relevant to dgVoodoo2.
If you're actually going to play Dungeon Siege one thing I figured out is that default Windows mouse cursor sometimes flickers over the game window, I found that hitting alt-enter to switch to window mode and back fixed it. That also applies to Kult: Heretic Kingdoms.
Reply 3113 of 3949, by ZellSF
I figured out why Massive Assault: Phantom Renaissance crashed on my main computer with dgVoodoo2. The game tries to set refresh rate to 60hz at start, somehow dgVoodoo2 interferes with this. If I manually set refresh rate to 60hz before starting the game it works fine.
But starting the game when the monitor is running a higher refresh rate = crash. Trying to force refresh rate to anything else with dgVoodoo2 = crash. Trying to change refresh rate ingame = not working (vsync stays at 60 FPS).
Edit: never mind that, starting the game at 60hz or 144hz works, everything else crashes, even refresh rates the games explicitly support. Any refresh rate works fine natively though, it's just dgVoodoo2 that has this problem. Not really an issue since I don't have any problems running the game at 144hz, but maybe interesting?
Also pretty please look at RIM: Battle Planets? Of the games I've posted that's the one I'm the most interested in playing with dgVoodoo2 enhancements.
Reply 3115 of 3949, by ZellSF
Dangerous Waters seems to work fine, though there's a separate topic about it. By default limited to 1600x1200 with sort of bad UI scaling so dgVoodoo2 might be beneficial.
1.05 MiB
Earth 2150 works great with resolution forcing, by default it's limited to resolutions less than 1800 lines, any more and you get issues with mouse cursor. Resolution forcing isn't entirely without drawbacks as 2D elements suffer a bit (look at the minimap).
1019.41 KiB
Panzer General 3D looks great with resolution forcing, but mouse cursor is not constrained to the screen. It also has some focus issues so I had to run it windowed. Sven's dedicated wrapper might be a better choice for this game (it needs some kind of resolution forcing as by default it's limited to 800x600).
878.54 KiB
Europa 1400: The Guild has issues, it has two exes, here's what the TL (hardware transform & lightning?) exe thinks the church interior should look like (bright dots and mirror should not be that bright):
105.5 KiB
And here's how the non-TL exe thinks trees should look like:
121.91 KiB
Natively the TL exe looks perfect, the non-TL exe just crashes. The movies also don't play (black screen, even in windowed mode). This was on the GoG build.
Reply 3116 of 3949, by ZellSF
Nexus The Jupiter Incident seemingly looks great with resolution forcing:
1.08 MiB
Until you hit escape and get this:
25.81 KiB
The GoG and Steam version has a way superior DX9 render with proper UI scaling implemented though so maybe not that interesting. What might be interesting is it shares behavior with Massive Assault 2: unless my desktop is set to 144hz or 60hz, it will crash at start (again, only with dgVoodo2, not natively).
Evolva seems to have some fog issues, here's how dgVoodoo2 displays it:
488.48 KiB
512.27 KiB
Might not be entirely obvious by screenshots but natively part of the mountain in front of the player character is obscured by fog, in dgVoodoo2 much less is obscured by fog, in motion this looks terrible as terrain will just come into view without being gradually "faded in" by the fog.
Republic: The Revolution seems to work great, by default limited to 1152x864:
1.81 MiB
Off-World Resource Base works great though it has perfect support for high-resolution as is and runs great natively. Empire Earth is the same if you use the hardware T&L render, but if you don't it will render terrain on top of the unit information screen.
Reply 3117 of 3949, by rcreif
No One Lives Forever works well with dgVoodoo on my desktop with AMD A8-6500 CPU, GeForce GTX 750Ti, and Windows 8.1 64-bit.
However, I'm here because it does not work on an older laptop I use when someone else is on the desktop. c. 2005-model HP Compaq 6710b, Intel 965 Mobile Chipset, no GPU, Windows 7 64-bit, 2GB RAM. Originally downloaded dgVoodoo v2.54 to fix the black-underwater glitch from Intel chips; otherwise the game works fine even without the CD, running "lithtech.exe -rez [all the REZ files]".
Everyone else on the Internet says that just moving D3D8, DImm, and DDraw to the install directory works fine, example https://pcgamingwiki.com/wiki/No_One_Lives_Forever. When I did that, message "NOLF Error: Couldn't set D3D Emulation Mode. Shutting Down NOLF..." appears.
Troubleshooting methods: Deleted the three files, NOLF ran successfully (except underwater). Added the files back one at a time, and the error was triggered specifically by DDraw.dll. Re-downloaded and re-extracted dgvoodoo, same D3D error message. Selected DirectX bypass box in dgvoodooCpl.exe, NOLF ran fine (except underwater). De-selected bypass box, same D3D error message. Deleted existing d3d.ren, same D3D error message. Restored d3d.ren from Recycle Bin, ran fine without dgvoodoo, error message with dgvoodoo. Manually copied entire NOLF directory via thumb drive to the desktop, NOLF ran fine including underwater, Display options revealed d3d.ren was detecting dgvoodoo. Manually copied entire NOLF directory from desktop back to laptop... same error message.
On the one hand, I get the sense the specific CPU (Intel 965 Mobile Chipset) is the problem. But I also distinctly remember playing NOLF on this laptop in the past with no issues, until one day it stopped reading the disc, hence the no-CD fix. Everyone on the forums swears by dgvoodoo, so what am I missing?
Reply 3119 of 3949, by rcreif
ZellSF wrote:
That GPU is just way too old for dgVoodoo2. Black water sounds like a driver bug. Not sure if it's possible to fix in any way, If you're desperate you might try messing with WineD3D, DxWnd and 3D-Analyze.
Too new to play an old game, too old to run the fix specifically designed to play old games? 🤣
