dgVoodoo 2 for DirectX 11
Reply 3420 of 3949, by lowenz
Commandos 2 (use Destination Paris mod to have all 3 Commandos missions in one package! 😁 ) + WIP40 = confirmed working
Choose THE LEGACY version folder to install the mod.
Reply 3421 of 3949, by kahuna0k
Do you have a voodoo.conf file that I could try? Maybe I'm using the wrong options.
Reply 3422 of 3949, by lowenz
Nothing special, really.
The Bilinear Blit Stretch is necessary to smooth the output if you use a custom resolution (I use 1440x1080, directly forced through dgVoodoo2)
Remember to use the LEGACY version in Steam (it's the original CD patched version) if you want to play the Destination Paris (1.45) mod.
In this case put the dgVoodoo2 DLL into the Legacy folder instead of the root folder.
Reply 3423 of 3949, by kahuna0k
I have the GOG version, maybe that's the problem, will try to find more info about the Legacy version.
Reply 3424 of 3949, by kahuna0k
Uhmm, I've checked and GOG Comandos 2 version is 1.20 and surprise! it runs without dgVoodoo but crashes as soon as I add the DLLs even without a .conf.
Reply 3425 of 3949, by Dege
Could you plz try the spec-release version of dgVoodoo and attach the output of the debug layer?
Reply 3426 of 3949, by daniel_u
In the DX tab of the app if i try to put my max video card memory which is 11GB,save then reopen the the app, the value that appers after is not corect.
It seems there is a bug in the UI. Always wanted to report this but always forgot about it.
So i try to put 11000 MB and after the save and reopen i get something like 1808 MB. Funny in a way.
Is there a limitation?
Reply 3427 of 3949, by Dege
Yes, the limit is 4GB (32 bit), but even 4GB is an overkill for old DX games.
11000 modulo 4096 = 2808, that's why you see that. 😀
Reply 3428 of 3949, by Gagster
I was just about to post a topic regarding the newest Windows 10 Fall Update breaking compatibility with Red Alert Yuri's Revenge using dgVoodoo2. The game returned to desktop while the RA2 main menu soundtrack was still playing in the background, and Alt+Tab didn't work while trying to return to the game.
Vanilla Red Alert 2 worked as it should after the Windows 10 Update (vanilla RA2 starts at 1920x1080 I believe if that's adjusted in your config, with the intro videos, title screen and main menu being small centered images surrounded by black borders, while Yuri's Revenge starts at 640x480 I think). A mod for Tony Hawk's Underground 2 called THUG Pro also got it's full-screen mode broken, making the games image slide a bit down to the right making the upper- and the left part of the Windows desktop visible while playing the game.
It all turned out that I had to use a new compatibility option now to be found in Windows 10, called "Disable full-screen optimisations" that's to be found below the Compatibility mode-slider. That fixed both Red Alert 2 Yuri's Revenge and THUG Pro.
CPU: i7-4790K
RAM: 16 GB
GPU: GeForce GTX 1080
OS: Windows 10 64 bit
Reply 3429 of 3949, by willow
A dx9 wrapper in dgvoodoo2 could be usefull because amd has introduced bugs in the last drivers with some old dx9 games and dont want solve theses problems
http://www.dsogaming.com/news/amd-will-most-l … renalin-driver/
Reply 3430 of 3949, by lowenz
Yes (not an "emulator" BTW), but it's the biggest step ever for dege and dgv development.
First thing first the DX10/11 pass-through.
Reply 3431 of 3949, by lowenz
Reply 3432 of 3949, by gdjacobs
I wasn't aware that he's still in the same position at AMD. Dude's been holding down the Radeon driver fort for a long time.
Reply 3433 of 3949, by Dege
DX9 is an api with a too long lifecycle with "millions" of games to be abandoned.
In spite of that, regarding that nothing lasts forever, I expect that it's going to get older and older in time.
I don't know if it'd worth to expose the present implementation behind dgVoodoo DX8 through DX9 interfaces. I mean, DX9.0 with only SM1.x support.
Are there games coded against DX9 but only for SM1.x? The one coming to my mind is Tomb Raider Angel of Darkness, but I'm not sure if SM1.x is only a fallback for cases when 2.x is not available.
Reply 3434 of 3949, by lowenz
DX9 SM 1.x eh?
Stalker "DX8" renderer is DX9 SM 1.x
Chaos Theory "DX8" renderer is DX9 SM 1.x
Far Cry 1.4 "low settings" preset is DX9 SM 1.x
And others.....we must unleash our hounds 😁
Reply 3435 of 3949, by Dege
So, hmm.... 😁
Reply 3436 of 3949, by VicRattlehead
Motorhead:
Maybe a problem with car shadows with the DirectX renderer?
DirectX
Glide
Software
Reply 3437 of 3949, by Myloch
Raising output resolution only brings benefits to d3d games huh?
I know this is probably a foolish question but is it possible to make something similar to software mode in epsxe where you can raise rendering resolution and have crisper 3d graphics in directdraw too?
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 3438 of 3949, by Dege
VicRattlehead wrote:
Motorhead:
Is it the same natively?
Yes...
For anything 2D you only get a blurrier appearance with potentially worse wrapper performance.
It turned out to be an issue recently for others too, so I introduced pixel multiplying as a feature in the latest WIPs.
The output image will still be pixelated but since you monitor is driven at a higher physical resolution, you'll get crisper appearance.
Reply 3439 of 3949, by VicRattlehead
Motorhead:
I don't have a contemporary setup. On my modern PC, it has the same problem without dgVoodoo2.
