[Help] Star Wars Episode I: The Phantom Menace - how fix fps animation (hex edit)
General information and assistance with dgVoodoo.
Postby legion_pheonix » 2019-11-12 @ 04:45
Please help me unlock at 60 fps.
I found such a hex line "89 88 08 3D" and changed it to "00 00 00 00".
The game was unlocked, but the problem remained with the animation of all units and characters, they remained at 30 fps.
If you turn on the console with the "backspace" key and type "60fps", then the animation becomes 60 fps
WMAIN.zip
(355.96 KiB) Downloaded 4 times
legion_pheonix
Re: [Help] Star Wars Episode I: The Phantom Menace - how fix fps animation (hex edit)
Postby teleguy » 2019-11-13 @ 17:28
I would try Cheat Engine. Scan the game, then set 60 fps via console and scan for changed values. Cheat Engine can also detect which part of the game's code is responsible for modifying these values.
teleguy
Postby legion_pheonix » 2019-11-13 @ 21:43
teleguy wrote:I would try Cheat Engine. Scan the game, then set 60 fps via console and scan for changed values. Cheat Engine can also detect which part of the game's code is responsible for modifying these values.
Thanks for the help, I started to do it yesterday. The Cheat Engine finds this address 0019FE20 with a hex value of 3C 88 88 89, but HxD does not display this address in principle.
I ask for help, I can lay out the game.
legion_pheonix
Postby teleguy » 2019-12-02 @ 16:23
teleguy
Postby teleguy » 2019-12-02 @ 16:24
It's probably just some address in RAM where the game stores that value, it's not inside the exe. Does setting or locking the framerate with CE work using that address? (The address might change every time you run the game though, so it might be better to repeat the entire process for testing.)
teleguy
Postby Dege » 2019-12-02 @ 17:36
0019FE20 is a typical stack-address for 32 bit applications.
So, the game (calculates or reads it from somewhere and then) writes that value to the stack for passing it as a parameter to a function.
Dege
Postby teleguy » 2019-12-02 @ 18:58
Dege wrote:0019FE20 is a typical stack-address for 32 bit applications.
So that address is pretty useless for our purpose?
teleguy
Return to dgVoodoo General
Who is online
Users browsing this forum: No registered users and 2 guests
