dgVoodoo Splinter Cell Games
General information and assistance with dgVoodoo.
Re: dgVoodoo Splinter Cell Games
Postby daniel_u » 2017-2-08 @ 22:00
TomArrow wrote:Dege,
I noticed something strange in Pandora Tomorrow. It is a small white cross flashing in the dead middle of the screen. I am not sure, but I think it happens more often when I use the mouse. Something Unreal-Engine related, perhaps. I can't show it to you, because it doesn't appear on my ShadowPlay recordings. It also doesn't appear when I use a different d3d8.dll from the Widescreen Patches pack. As for the looks ... it's just two perfect white lines crossed, static, not changing with motion or anything. If you need proof, I'll try and record it with my digital camera.
Try to check App controled fullscreen(DX tab). The other option Disable Alt enter unchecked.
While running the game:
Alt +enter, after fullscreen-window mode madness,if you loose focus
Also uncheck capture mouse in the General tab.
See if this helps.
User avatar
daniel_u
Postby Dege » 2017-2-09 @ 13:03
Yes, bold crosshair cursor usually appears (for Unreal engine games) when the game window doesn't have the focus.
Should try to patch SC1 to avoid that windowed mode annoyance.
Dege
Postby Dege » 2017-2-09 @ 13:08
CoolGamer wrote:
Dege wrote:This made me ponder.
Such additional rendering passes could only be done "inside dgVoodoo" (if we stick to D3D11 rendering techniques).
External post processors can only see the final frame image, including 2D HUD.
While I don't want to include any game-specific thing into core dgVoodoo, for some time I'm thinking about an internal hooking layer,
through which additional logic could be organized into separate modules (dlls).
The rendering part to be hooked could be identified by some uniqe renderstates and some extra rendering could be added in those case.
UCyborg mentioned Mafia Water Shader Mod, that one does the same (with a custom D3D8.dll for API hooking).
I should whip up a proof-of-concept.
Dege,
Did you have the chance to look into Nvidia Gameworks source code/examples? Can Gameworks effects (HBAO, DOF, etc.) be used in dgVoodoo's upcoming internal hooking layer through separate modules (dlls)?
Yes, I'll have a look into it.
The problem is, there are so many things to fix, that I cannot give it high priority. :(
But, the first step, quickly whipping up an external "add-on" for dgVoodoo might not be a heavy time-consuming task.
Dege
Postby TomArrow » 2017-2-12 @ 21:40
Heya .. not sure this has anything to do with dgVoodoo, probably hasn't, but does anyone here know a solution to the 30fps cap in Chaos Theory's Versus mode?
Update: Solved. There's a tool called "Framer" which does it.
TomArrow
Postby daniel_u » 2017-2-15 @ 07:55
@Dege i've added some pictures for SC1, in the main post, with the current issues.(tested also with WIP 30).
I know that WIP 30 doesnt address the issues there but i used WP30 for comparison.
User avatar
daniel_u
Postby daniel_u » 2017-2-25 @ 22:58
With latest WIP i'm seeing a issue with the sky, never seen it before:
(somehow is related to the mouse move, on original hardware this is not happening. I checked.)
Normal
As you can see smoke and clouds disappear. Strange.
If will look into this issue, are you willing to check why some lights/corona effect around light and shadows flicker/disappear/appear with mouse movement(these are happening with original hardware)? I'll post some save games if you 're willing. I would love to know whats happening ! Please !!!
Also , as others reported, there is a big plus sign/cross in the middle of the screen , flickering.
Thanks.
User avatar
daniel_u
Postby daniel_u » 2017-3-20 @ 18:05
@Dege WIP 31/32 fixed the focus lost alt-tab issues.
User avatar
daniel_u
Postby daniel_u » 2017-4-14 @ 08:42
Rain issue WIP34
User avatar
daniel_u
Postby daniel_u » 2017-4-21 @ 17:36
WIP 34_1 fixed the mouse issues introduced in previous wips
User avatar
daniel_u
Postby daniel_u » 2017-5-08 @ 13:39
Hi Dege,
I've tried SC1 in 4k, resolution forced in DgVoodoo and i got some issues:
Previuosly, there were 1-2 places in SC1 with certain issues when forcing resolution or MSAA applied. I know the feature can create problems but If you can keep the issues at minimum it would be awesome if not, well, it happens :).
Thanks !
User avatar
daniel_u
Postby daniel_u » 2017-6-17 @ 13:01
So i've tested this issue more. It seems it appears in 2.53 also and i went with testing as low as WIP 28. The 4k issue is still present. And also the rain issue that has been fixed already.
So for now there are 3 occurences with resolution and MSAA forced. Best option is to force res with the ini file or some other wrapper like the widescreen one.
User avatar
daniel_u
Postby lowenz » 2017-7-23 @ 07:38
Daniel, is this the correct behaviour on old platforms?
lowenz
Postby daniel_u » 2017-7-23 @ 13:14
lowenz wrote:Daniel, is this the correct behaviour on old platforms?
Yes, seems to be the same.
User avatar
daniel_u
Postby lowenz » 2017-7-25 @ 10:02
Daniel, how can I open/bring down the console in SC2 ?
Or it is locked?
lowenz
Postby daniel_u » 2017-7-25 @ 19:35
lowenz wrote:Daniel, how can I open/bring down the console in SC2 ?
Or it is locked?
Imho there is no console available. If there is one i dont know about it.
If you want to enable cheats the look it up on google. If you want to record some gameplay and replay it later(feature used alot in SC1 for benckmarking back in the day) you cant. There is no such feature.
That's what you get when Ubisoft Shanghai does games,
SC1, SCCT, SCDA(xbox original) UbiSoft Montreal.
SC2,SCDA(PC, Xbox 360) Ubisoft Shanghai
It really shows.
User avatar
daniel_u
Postby lowenz » 2017-7-25 @ 21:34
With the console I can load up on-fly the OpenAL subsystem instead of the default DareAudio subsystem. I'm using the OpenAL Soft implementation (CPU only) and in SC1 it seems working well :p Need more testing.
lowenz
Postby lowenz » 2017-8-01 @ 10:26
The beauty of SC 2002 lighting engine (Sam's shadow over the moving flag):
lowenz
Postby daniel_u » 2017-8-07 @ 07:04
lowenz wrote:The beauty of SC 2002 lighting engine (Sam's shadow over the moving flag):
Yup. The artwork and effects are really nice . You should give SCDA for xbox OG a try. I think it's the best of the series. Ok maybe SCCT it's the first. :)
Too bad there are no modders and devs interested in fixing the games,fully. For example SCPT has that nasty bug related to the color of the light. It really breaks the immersion.
Dege could but he has other priorities. I dont blame the man,i really admire his dedication to his project. +1
User avatar
daniel_u
Postby mannyca05 » 2017-10-19 @ 21:56
Hello, can someone help me with the shadows in SC1? Looks really bad in comparison with https://pcgamingwiki.com/images/thumb/3 ... arison.png
Splinter Cell (Steam version) I did everything by PCGamingWiki FAQ - https://pcgamingwiki.com/wiki/Tom_Clanc ... er_shadows
I'm not using PS3 HD Textures and Widescreen Fix
mannyca05
Postby lowenz » 2017-10-20 @ 09:10
Bad?
lowenz
PreviousNext
Return to dgVoodoo General
Who is online
Users browsing this forum: No registered users and 2 guests
