dgVoodoo Splinter Cell Games
Reply 100 of 110, by AngryLittleAlchemist
I somehow ended up going down a rabbit hole of supposed fixes to the "bad image error"(or at least that's what I think it's called?). I got recommended messing with Windows 10 updates because apparently a lot of the forced ones ruin compatibility with certain software so I had to go and stop delete the updates and then stop Microsoft from automatically downloading them, didn't work. Somehow that led to a Bios update being a possible fix, which I was skeptical of, and while that was easy to do it took me 10 minutes to realize that the BIOS wouldn't recognize my keyboard because it was in the USB 3.0 slot instead of the USB 2.0 slot. That didn't work either.
I downloaded the microsoft debug tool from the debug layer thread and I don't think that did anything (although honestly I'm pretty sure I didn't use it correctly). If there's one thing I've learned from all this it's that I'm in no way a computer expert ...
edit: Sorry, I know that i'm not being very helpful, no one here probably knows the answer, just thought i'd log it to be sure, and also to vent 😀 🤣
edit 2: I just tried scanning the DLL file, scanning windows files. Spent a bunch of time making commands that would unregister and re-register dlls, none of it worked. 😠
Reply 101 of 110, by AngryLittleAlchemist
Oh my god! I got it to work!
All of these insane, complex fixes I attempted and I didn't even try the easiest fix of all ... downloading an older version of DgVoodoo! For me, the latest version of DgVoodoo does not work, but the last version, DgVoodoo 2.55.1 works! The funny thing is, I was at my wits end and the only reason I figured this out was by contacting some random user on a subreddit thread that was already months old. Haha!
Thanks for everyones help on this board - and hopefully if you have the same problem - installing the last version works!
Reply 102 of 110, by diagonally
Game: Splinter Cell: Pandora Tomorrow
dgVoodoo version: 2.55.4
dgVoodoo settings: https://pcgamingwiki.com/wiki/Tom_Clancy%27s_ … s_on_modern_PCs
Issue: The game (menus and actual gameplay) appears to be significantly dimmed. This is fixed by entering and exiting the options menu on the initial screen, at which point the proper brightness is restored.
Reply 103 of 110, by ed_barber
In the CIA HQ and Oil Refinery missions, there is bug appearing in dgVoodoo 2.61 where some textures appear to be black. See images below.
190.15 KiB
CIA HQ
500.12 KiB
Oil Refinery 2
396.62 KiB
Oil Refinery 1
Reply 106 of 110, by hishamerrish
Hi guys ... i really love this game
so i tried something that gave some good results
I replaced the ( ETexRenderer.utx) from SC1 with the one from SCPT ... i got stronger light and smoother shadows like the xbox original ... here is Comparison photo
https://imgur.com/a/WtyLeA2
i tried to replace the ETexSFX.utx too ... it fix rain rendering in Kalinatek mission ... but corrupt it in other missons
i hope i could help you .... keep the great work ...
Reply 107 of 110, by hishamerrish
HI GUYS
i have strange bug ,...
The guards Bodies looks not right from far a way or through the sniper ... i do not know if any one has seen it before
thank you
here is a screen shoot
https://imgur.com/a/orhhp
Reply 108 of 110, by daniel_u
hishamerrish wrote on 2020-01-25, 01:31:
Hi guys ... i really love this game so i tried something that gave some good results I replaced the ( ETexRenderer.utx) from […]
Good find.I need to try this. 😀
Reply 109 of 110, by daniel_u
hishamerrish wrote on 2020-01-26, 01:45:
HI GUYS i have strange bug ,... The guards Bodies looks not right from far a way or through the sniper ... i do not know if any […]
HI GUYS
thank you
Yes, i know. But it's not the wrapper. Its the game engine. I tried some commands some time ago but nothing helped.
Without some dedicated dev/modder that really loves this game these will stay like this forever. 😀
Reply 110 of 110, by hishamerrish
daniel_u wrote on 2020-01-27, 07:49:
HI GUYS
thank you
hi
i found its happening when i use 4k or AA with the game ... dose not happen with the 2k or 3k .... i tried many thing but no luck 🙁 ... i wish modders do some thing to fix this game 😀
