DGV 2.54a and Raven Shield
General information and assistance with dgVoodoo.
Postby lowenz » 2017-5-15 @ 10:53
Dege, can you check 2.54 in Raven Shield 1.60 ?
I got a crash in fullscreen mode loading a mission level.
No problem in windowed mode (set from the game itselft via config file), except you can't move the window.
Is there any way to force (maybe in future versions of DGV) the starting X and Y of the active main window?
lowenz
Re: DGV 2.54a and Raven Shield
Postby Dege » 2017-5-22 @ 20:04
lowenz wrote:Dege, can you check 2.54 in Raven Shield 1.60 ?
Ok, of course, I just need a free time slot for that. :)
For hacking window position and other titbits, I should implement a text format config file, I think.
Dege
Postby lowenz » 2017-5-22 @ 21:46
And (how) they can be prioritized over game's own parameter - of window corner (X,Y) - values? (if present)
lowenz
Postby Dege » 2017-5-23 @ 08:08
lowenz wrote:And (how) they can be prioritized over game's own parameter - of window corner (X,Y) - values? (if present)
Well, it all should be figured out, later.
Dege
Return to dgVoodoo General
Who is online
Users browsing this forum: No registered users and 3 guests
