First post, by b_m_l
Tomb Raider 3 + dgVoodo (+Reshade) = everything white Oo any suggestions?
Reply 1 of 6, by Dege
Weird... TR3 works for me.
1. Try to launch TR3 with the -setup option (TR3.exe -setup) to reconfigure your graphics settings.
2. If it still doesn't work then could you plz post me a debug-log using the spec-release version of dgVoodoo?
Reply 2 of 6, by Nucleoprotein
Not broken at all - you enabled 8bit textures in configuration and dgVoodoo is not supporting them properly - so no textures at all. Use ATI card in Control Panel, it disables 8bit texture support and game will not enable them at all.
