dgVoodoo2 and IG performance as an auxiliary GPU
General information and assistance with dgVoodoo.
Postby lowenz » 2018-12-22 @ 12:05
Surprisingly I found that dgVoodoo2, running it in a window on integrated graphics (Intel 530), performs BETTER using the monitor connected to a dedicated GPU (my primary GPU, GeForce 1050 Ti via DVI) than the monitor connected to itself (via HDMI)!
11% performance gain (Unreal with the original renderer runs @200 FPS vs 180 FPS)
Is this expected? GPU can dedicate itself to the 3D rendering/rasterizing only so it's 11% better?
Of course you're limited to the windowed mode (no exclusive fullscreen nor borderless windowed fullscreen either)
lowenz
Re: dgVoodoo2 and IG performance as an auxiliary GPU
Postby Dege » 2019-1-04 @ 18:31
Yes, the Intel GPU is doing only the rasterization in this case. After that, the image is copied to or accessed directly by the nVidia GPU from shared video memory. I mean, shared between the two GPUs. 2D textures without MSAA can be shared starting from D3D9Ex, but how it's exactly done is up to the desktop compositor (DWM).
It is still strange, I wouldn't expect that either. Maybe composing the desktop part covering the Intel monitor is slower than accessing the image by the faster GPU from a slower memory?
Dege
Postby lowenz » 2019-1-04 @ 19:18
Oh thanks!
lowenz
Postby lowenz » 2019-1-07 @ 10:45
re-tested now, same results :D
lowenz
Postby UCyborg » 2019-1-07 @ 14:39
Anyone here knows the answer to this question?
UCyborg
Return to dgVoodoo General
Who is online
Users browsing this forum: KainXVIII and 2 guests
