Witcher 1 dgvoodoo
General information and assistance with dgVoodoo.
Witcher 1 dgvoodoo
Postby standly90 » 2018-12-31 @ 11:33
Hi,
I've tried to run Witcher Enhanced Edition(steam version) on Win10 with dgvoodoo wrapper and it doesn't work. I've enable watermark and it doesn't appear in the game. What am I doing wrong?
standly90
Re: Witcher 1 dgvoodoo
Postby Dege » 2018-12-31 @ 12:33
You need D3D9.DLL from dgVoodoo, Witcher 1 is a d3d9 game.
Dege
Postby standly90 » 2018-12-31 @ 12:53
And how can I get it?
standly90
Postby Dege » 2018-12-31 @ 13:16
For the time being it's available only in WIP (work-in-progress) versions, try the latest one:
viewtopic.php?f=59&t=51790&start=780#p723430
Dege
Postby standly90 » 2018-12-31 @ 13:32
So it works.
But it didn't solve my problem. When I play (and for example when I run), the screen is freezing for 1 second for every 10 seconds maybe. Should I change something in settings in panel?
standly90
Postby standly90 » 2019-1-01 @ 16:10
Anyone can help with this?
standly90
Postby willow » 2019-1-01 @ 18:02
standly90 wrote:Anyone can help with this?
It's a WIP, bugs can stay.
You must try others parameters and if it doesn't work, you must wait the next release of a new version of dgvoodoo working with the witcher.
willow
Postby standly90 » 2019-1-02 @ 17:56
Thanks for information. I can't wait for next release then, because game is now unplayable :/
standly90
Postby Dege » 2019-1-04 @ 18:23
standly90 wrote:So it works.
You mean the freezing problem occurs even without dgVoodoo? If so, then it's not a rendering problem but some other.
Unfortunately subsequent dgVoodoo releases won't help that too.
Try to check out if freezing is not caused by memory swapping or disk-reading or some other general operating system resource management.
Dege
Return to dgVoodoo General
Who is online
Users browsing this forum: No registered users and 2 guests
