First post, by JunglePredator
Hi.
Would you be able to look into getting Drakensang 2 to work on WIndows 10? It works for some & not others based on... what I don't know.
It fails with an assertion error from the game engine which the company indicates is a "known error for unsupported graphics cards".
Specifically their notes for this at http://www.fxinteractive.com/p222/ayuda.htm#9 is (Google translated):
"This issue occurs when the game is run on computers with graphics cards not supported by the program, or under cards that do not have their drivers installed correctly. It can also occur if you do not have the latest version of DirectX installed.
As indicated in the minimum product requirements, "Drakensang" only works with graphics cards with 256 Mb, ATI Radeon X800 or higher and NVidia GeForce 6600 or higher. If you do not know what your graphic card is, you can find out by consulting the DirectX diagnostic tool.
To do this, click on the "Start" button and select the "Run" option. (If you use Windows Vista, the "Run" option is located under Start> All Programs> Accessories). When the "Run" box opens, type "dxdiag." If the DirectX Diagnostic Tool asks you if you want to check the digital signature of your controllers, select "No". Once the diagnostic tool is loaded, click on the "Display" tab and note in the "Device" box the name and manufacturer of your card, as well as the amount of memory, next to the text "Total memory approx."
If your graphic card meets the requirements, make sure you have your "drivers" updated properly. See our "Drivers Guide" for more information. Finally, make sure you have the latest version of DirectX installed. To do so, run the "DXSETUP.exe" program that is located inside the "DirectX" folder of the "Drakensang" DVD. If you are not sure how to perform these operations, do not hesitate to contact our Customer Service. Our contact information can be found here ."
dgVoodoo seems like the most likely project for it to get working under but I've been unable to find a setting to work.
Reply 1 of 19, by ZellSF
Chances are the people it doesn't work for have some conflicting background software, haven't actually installed DirectX or some problem with their Windows installation. If it was me I would figure it out, because it's likely not going to be the last game that will give you a problem with it.
It's a D3D9 game so you need the WIP:
WIP versions
It "works" out of the box, using the common Drakensang troubleshooting tip of running it -windowed , but since that has problems of its own then running it in forced borderless in dgVoodoo2 is better. That sadly for now involves editing dgVoodoo.conf manually, these are the important settings:
FullScreenMode = false
WindowedAttributes = Borderless, FullscreenSize
AppControlledScreenMode = false
DisableAltEnterToToggleScreenMode = false
Mouse coordinates in menus will (probably) be wrong until you set game resolution to match desktop resolution. I would personally advice against using WIP software to run a lengthy RPG when the game should run natively (good general rule: if it works for others and not you, you're doing something wrong).
The attachment drakensang.jpg is no longer available
Reply 2 of 19, by JunglePredator
ZellSF wrote:
<snip></snip>
Thanks for trying to help however most of this is old notes already expressed on the Steam forums & not very helpful.
The only thing mentioned that might have helped was
but alas it changed nothing.
MS ACT is suggested by one person with the change of "simple window" applied... likely it already had such changes to it but the setting was tested anyways... just in case.
The game is a 50/50 chance to work for people... likely it'll need someone like Dege to actually look at how it's accessing the memory.
From what I've been able to tell from forum posts is that the DVD edition is more likely to work than the Steam edition & each build of Windows 10 may break it for some & fix it for others (i.e. if it's running for one person when windows updates & the game may no longer run).
Reply 3 of 19, by teleguy
The only thing mentioned that might have helped was […]
The purpose of simple window in this case is to make the window borderless if the -windowed command line switch is used. Itself it doesn't make a difference in the game working or not.
BTW both games (Steam versions) work fine for me on Windows 10 with and without dgVoodoo.
What kind of hardware do you have?
Reply 4 of 19, by ZellSF
If it's old notes, you still have to write down whether or not you tried them. Detail all the troubleshooting steps you have already done, then we can consider moving on to the next step, rather than starting from scratch.
I can't even at this point tell whether or not you tried with the latest WIP, nor the exact failure you get with the latest WIP, which would probably be Dege's main concern; his priority seems to be developing dgVoodoo not hacking games to work on newer OSes.
Both the DVD version works (for me) and the Steam version works (for teleguy), eliminating the Windows 10 version issue is fairly unproblematic, just run Windows Update. It runs fine on fully updated 1809 and 1903.
Those aren't the problem. Look for other variables in your setup.
Reply 5 of 19, by JunglePredator
Yeah; if you can run the DVD edition the Steam edition is almost guaranteed to run it seems.
Threads like https://steamcommunity.com/app/12640/discussi … 97653307567432/ & https://steamcommunity.com/app/33770/discussi … 40247772952269/ give info on people trying both.
If you can't run the Steam edition the DVD is more likely to run but also a good chance you'll still receive whatever errors you get from the Steam edition.
However I'm not in a position to try the DVD edition.
The pertinent 4 items would be OS, CPU, GPU & SRAM: Win. 10 b.1511, I7 octcore something, 1050 TI & 16GB DDR5.
I wouldn't post if I didn't meet the minimum specs. of course. The odd one out there is Windows 10; it's not officially supported.
Based on what I can find on forums hardware barely matters to whatever the error is; I've seen posts of people with 1xxxx cards of the same model as each other able to run it & not able to run it on the same Windows 10 build.
https://steamcommunity.com/app/12640/discussi … 97653307567432/ has the best information for things people have tried; it seems to be the best thread for an overview of troubleshooting... if it's even hinted at there I've tried it as well as: replacing the files with the 1.12 patch files (that's sort of hinted at on page 2 but they only talk about the command line options the patch uses like -reset), Wine DLL replacements, dgvoodoo with various command line options (like the once mentioned -D3D9 option), removing the Drakensang 2 profile (not that it matters... it's remade each time the game starts but it's blank because the game crashes with the assert error as soon as the blink32 video player ends), the 1.12 patch had an indicator they remove virtual store files (namely a virtualstorecleaner.exe).... sadly there's nothing on my system relate to Drakensang 2 there.
Reply 6 of 19, by ZellSF
Um, those discussions are about different issues than the one you linked to in the first post (failure in GetDeviceCaps() function).
How about you just say exactly what you have tried, and exactly what goes wrong already?
Reply 7 of 19, by Dege
Drakensang also works for me, usable only in windowed mode though (natively and with dgVoodoo).
I thought I tried the first part but by the screenshot it turned out (for me) to be the second.
I don't know if all todays graphics cards/drivers are compatible natively with this game, but I think it should just run through dgVoodoo.
Plz download the spec-release (debug) version of dgVoodoo, give it a go with Drakensang and attach the log.
According to the symptoms you described, I have a feeling the game loads system D3D9 instead of dgVoodoo for some reason.
Reply 8 of 19, by JunglePredator
Dege wrote:
Drakensang also works for me, usable only in windowed mode though (natively and with dgVoodoo). I thought I tried the first part […]
Attached.
Reply 9 of 19, by Dege
Thanks!
So, I was wrong and dgVoodoo gets activized for you. According to the log nothing abnormal happens but the game just exists at some point (ok'ing the error dialog popping up?).
I read through the forums you linked. Experimentally I modified dgVoodoo to give back an error for Device::GetBackBuffer. Indeed, I got the error dialog and the game behaved as 'expected'. On the other side, I cannot understand how it could return an error code under normal circumstances.
Parameters of that call are not hardcoded into the game, so the only possible case is some memory corruption somewhere.
Are you sure you don't have any unusual things installed (compared to a clean OS installation) that injects code or some dll's into the processes?
Like an AV (my favorite *** ***** type of software) or maybe a vendor specific preinstalled stuff for "making mouse handling and easy task switching smart" and alike?
To clear it up, looking at the dlls loaded into the game process would worth a go.
Reply 10 of 19, by JunglePredator
Dege wrote:
Thanks! So, I was wrong and dgVoodoo gets activized for you. According to the log nothing abnormal happens but the game just exi […]
Thanks!
I'll look at my AV... I never thought about it. It only gives me grief when games don't close deal with ports well/correctly & are full screen.
Other then that I don't have anything 'unusual' at the moment... nothing doing hooks that I'm aware of.
There's a shit ton of MSI processes for the motherboard... I don't know what they do as they lack descriptions & I don't know which are 'safe' to turn off... there could be a memory interference there if it's caching or something.
Beyond that it's normal stuff... have to have Steam running (as you saw in the log) because of the game's DRM, usually have EA's Origin running...
Reply 11 of 19, by ZellSF
00000030 73.92550659 [7432] [dgVoodoo] INFO: Direct3D9 (01163FA0) Virtual video card is 'GeForce FX 5700 Ultra' with 256MB onboard memory.
1) Use the default config when troubleshooting (copy dgVoodoo.conf from the archive to the game directory). Do not make any config changes you're not explicitly asked to.
2) A GeForce FX 5700 Ultra does not support shader model 3.0, which Drakensang 2 requires. Always stick with the default "dgVoodoo Virtual 3D Accelerated Card" unless you have a very good reason not to.
Reply 12 of 19, by Dege
My first guess was the same but I tried the game with GeForce FX 5700 Ultra, 256MB and it worked.
Reply 13 of 19, by ZellSF
Personally I'd go back to my original suggestion then for JunglePredator then: write EXACTLY what happens IN DETAILS.
Reply 14 of 19, by JunglePredator
Well a list of loaded DLLs is at https://pastebin.com/5Ni5RuSf
If you feel like helping that'd be cool or you can close the topic since it's not dgvoodoo focused anymore.
All the DLLs are signed except the ones in the Drakensang 2 directory... dll list is with out dgvoodoo loaded just to get a 'pure' list.
No idea how to stop it from loading any of those & most look fine... only a couple make me go "why?"... like SETUPAPI.DLL
Tried deactivating the real time scanner of the AV & no joy... only step further I could go there is to uninstall it but that's not an option since it's also my firewall which I do need.
Steam Overlay still loads but isn't selected to be used in options.
Reply 15 of 19, by ZellSF
You haven't actually said what the problem is yet; is it what you posted to about in the OP or one of the ones posted about in the Steam forum links? In which case which of them?
Reply 16 of 19, by xcomcmdr
Windows has a firewall built-in since Windows XP., and an AV since Windows 8.
You can uninstall your AV/Firewall bundle.
Reply 17 of 19, by teleguy
You can use msconfig to launch Windows in diagnostic mode with only basic processes and services running.
Reply 18 of 19, by JunglePredator
Good idea; I'll post on that later tonight.
Edit: Wasn't feasible... game didn't load with out directsound initializing & wasn't worth going through the couple hundred drivers & services to check which might have an impact.
Reply 19 of 19, by Terelyn
I tried it with Windows 11 and the game doesn't work in fullscreen and there is only a black screen during the intro without a third-party wrapper. It works mostly perfectly with dgVoodoo2, though. I don't know if it's fixable, but If you don't uncheck "Disable Alt-Enter to toggle screen state" there is a double cursor and it throws you back at the desktop if you try to click on anything.
