First post, by ladderman
Hi
I just got this game from Amazon,and i got it installed okay.When i was playing i noticed the main character in the T-pose,so i followed the steps on the pcgamingwiki Scarface page on Corrupted graphics section:-
This involved putting the DgVoodooCpl.exe & D3D9.dll in the games directory.
https://www.pcgamingwiki.com/wiki/Scarface:_T … en_refresh_rate
My main character was not in the T-pose anymore,but i was getting weird graphics whilst playing the game(see uploaded images).Does anyone know a fix for these weird graphics i'm getting?.
Thanks in advance
Colin
PS My problem has been discussed already in this forum:-
https://community.pcgamingwiki.com/topic/4606 … 36&_fromLogin=1
My System Specs
Windows 10 Home 64 Bit
Gigabyte Z370 AORUS Ultra Gaming: ATX, LG1151, USB 3.1, SATA 6GBs
Intel Core i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
1TB SEAGATE FIRECUDA 3.5" SSHD
6TB WD BLACK 3.5" WD6001FZWX, SATA 6 Gb/s, 128MB CACHE (7200rpm)
CORSAIR 650W TXm SERIES SEMI-MODULAR 80 PLUS GOLD, ULTRA QUIET
8GB AMD RADEON™ RX 580 - HDMI, 3 x DP - DX 12
Creative Sound Blaster Zx 5.1 PCI-E Soundcard
32GB Corsair VENGEANCE DDR4 3000MHz (2 x 16GB)
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
AOC G2770PF LCD 27 inch Monitor
    62.22 KiB
    27.46 KiB
    66.8 KiB
Reply 1 of 2, by Dege
Strange, it works fine here.
Could you check it plz with the MS WARP output? It'll be slow but the point with that is to check if the rendering is as expected.
My tip is, you have and AMD card, on which dgVoodoo reportedly works improperly. Solid colors instead of textures and such. 🙁
Reply 2 of 2, by ladderman
Hi Dege
I managed to fix my problem.I did by Downloading 3D Ripper FX from here:-
http://www.deep-shadows.com/hax/3DRipperDX.htm
I then started 3D Ripper FX,and selected the Scarface.exe.Then i started Scarface from the app and it worked fine.
Yes using the MS WARP output solved the problem as well,but you're right it was slow.
Thanks for pointing me in the right direction.
Colin
